Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-16-2013, 04:49 PM
88D250's Avatar
88D250 88D250 is offline
Z Member
Vehicle: 1988 Dodge Ram
Trim Level: D250
Color: Grey
88D250 is on a distinguished road
Default Ignition Problems
1988 D250 318, will not start. It cranks, but no ignition, there is no spark. I have replaced sparkplugs, distributor cap and wires, and solenoid. I purchased an Ignition Control Module, but cannot find the old one for the life of me. Any input would be much appreciated.
Old 04-17-2013, 12:51 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
An '88 318? That'd be fuel injected, right? If so, and I'm pretty sure it is, there is no ignition control module. The ICM is on carbureted models, which in 1988 would've been only the 360-equipped models. Most commonly, on these early injected models, your issue is caused by a failed ignition pickup, aka fuel pump relay. This module fits in the distributor body below the rotor. It's easiest to change the relay by pulling the distributor out. They can last 2 years or ten years. It all depends on the mileage. Personally, I prefer the ICM units, but they didn't ask. Thankfully, this arrangement was only used for about 4 years.
http://www.rockauto.com/catalog/more...888&cc=1085947
Now, it for some reason you managed to get an early '88 318 and it had a carb (stranger things have happened) the problem could be elsewhere.
Old 04-20-2013, 10:33 PM
88D250's Avatar
Z Member
Trim Level: D250
Color: Grey
Nah, this things carbed. Its been suggested that it may be something to do with the computer in the fender behind the battery. Single Module Engine Controller?
Old 04-20-2013, 11:25 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
you sure it is carbed? only reason i ask is holley also made the throttle bodies for the TBI system and they look a lot like a carb until you take the air cleaner off.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 04-21-2013, 09:12 PM
88D250's Avatar
Z Member
Trim Level: D250
Color: Grey
Hmm, I suppose I'm not really sure. I've only just recently had the time to start this project, so I havent had a chance to familiarize myself with anything yet. I hope to know my way around by the time summers through.
Old 04-22-2013, 11:50 AM
bighemi04's Avatar
Rep:623
Starter relay or the steering column. My buddy had an 87 ramcharger and we replaced 3 steering columns and numerous starter relays to handle its ignition problems.
Old 04-22-2013, 04:54 PM
i think the problem would have had to be else ware if you had to go through 3 steering columns and multiple starter relays. you can test all that stuff with a basic multi meter. no point wasting time and money swapping parts if you can test it with a tool that anyone with a older truck should have anyway or you can get cheap enough at a parts store.
Old 04-25-2013, 03:18 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Have you tried replacing the ballast resistor? will do exactly what you are describing and cost around $3.00 brand new.
It regulates the power to the coil to start the truck. 12v while starting and then around 6 once it starts.
I always kept a spare in the glove box.
Old 04-25-2013, 06:16 PM
if it is TBI like it should have been from the factory there should not be a ballast resister
Old 04-25-2013, 06:37 PM
Vehicle: 95
Rep:1776
I had a '90 Ramcharger
that for some reason had the BR with the double prongs.
1988, d250, ignition
