Amp Rack Mounting - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-16-2013, 10:01 PM
GAltima GAltima is offline
Vehicle: 2010 Ram 1500
Rep:40
GAltima is on a distinguished road
Default Amp Rack Mounting
Just curious how everyone is mounting their amp racks to the rear cab wall of the quad or crew cabs. I plan on sound deadening before mounting the amp rack. Due to the weather here in Wisconsin and the huge amounts of salt spread on the road in the winter, i don't want any holes or screws to go through the cab to the outside. I have all my equipment and am ready to start installing but want to make sure i have a plan before i get started. This is my daily driver and my girlfriend's kids usually ride with me so i want to keep the install time as short as possible. I'm open to suggestions here. If i wasn't using sound deadening material i would just use liquid nails and glue it to the back wall. I haven't had the rear seats out yet so not quite sure what i'm dealing with back there.
Old 04-16-2013, 10:47 PM
Rep:3337
Most mount to the rear wall, which is the strongest connection, but if you don't want to drill through the rear wall then your options are limited. You can mount a lower lip to the rear floor, but then the top in unsecured and could rattle. You can always use construction adhesive if you never plan to remove the amp rack.
Old 04-16-2013, 11:55 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Like to know what you end up doing, when I do a audio install I'd like no holes penetrating through to the outside.
Old 04-17-2013, 07:42 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
3M has a double sided tape that is like the adhesive Dodge uses to mount their emblems on our trucks. Your amp rack will not be going anywhere with this product. You can find it at Lowes or Home Depot. Paint the entire rack if you're using wood...this product sticks better if the wood is painted.
Old 04-17-2013, 10:11 AM
Racerdamon's Avatar
Racerdamon Racerdamon is offline
Vehicle: 2010 Dodge Crew Cab
Rep:145
Racerdamon will become famous soon enoughRacerdamon will become famous soon enough
I used hd velcro and it has worked great!
Old 04-19-2013, 03:26 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
I would use velcro before drilling -- unless your amp weighs 15#.
Old 04-27-2013, 04:59 PM
th8785 th8785 is offline
Vehicle: 2007 dodge ram
Trim Level: sl
Color: silver
Rep:14
th8785 is on a distinguished road
i used industrial strength velcro on the metal wall, no sound dampening or amp rack. completely covered the back of the amp. it sits on the floor so velcro really doesnt support the weight, just holds it in place. works great though.
Old 04-27-2013, 08:09 PM
Racerdamon's Avatar
Rep:145
Nice!! Rep to ya
Old 04-29-2013, 12:59 AM
ImAHemi ImAHemi is offline
Vehicle: 09 Ram QC
Color: Deep water blue pearl
Rep:24
ImAHemi is on a distinguished road
I cut a board to fit the void behind the rear seat, I fabricated brackets to bolt to the rear seat tether locations. The bottom is held in place by my bottom panels but could also be held in place by fabricating a bracket to be held in place by the sat bolt. My amplifiers are secured to the board using 1/4-20 machined button head cap screws and hurricane nuts. The only non repairable hole in my truck was drilled to bolt the sub enclosure in.
I would advise against velcro for installation of any amplifier, in the event of an accident no matter how strong the velcro, and object can still become a flying object.
Any questions about the instal, just ask.
Old 04-30-2013, 11:38 PM
thmupr thmupr is offline
Vehicle: 2014 Ram Sport
Rep:12
thmupr is on a distinguished road
I made a board that kinda covers everything under the "ledge" behind the seat.
I used some flat steel brackets to mount the board to the "ledge", as that part is double wall (see pic).
The boards also had 3M double side stick on the back. This was my original install, I've since redone it, but its basically the same idea.
