Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-17-2013, 09:47 AM
PatrickHenry's Avatar
PatrickHenry PatrickHenry is offline
Vehicle: 2001 Dodge Ram 2500
PatrickHenry is on a distinguished road
Default A/C Vent/Vacuum Problem
I'm having what would seem to be a vacuum related issue on my 2001 Ram 2500 with a 5.9 gas burner. With the A/C on, if I start pulling a hill it'll switch to the defrost. I had the same problem with my old ford f-150 that turned out to be the plastic vacuum lines crumbling and losing vacuum.
However, this seems to be a little different. I can stop, hold the brakes and put the pedal on the floor and there's no change. But from an idle in park I can push inward on the selector switch itself and replicate it. That's what has me puzzled, anyone have any ideas?
Old 05-01-2013, 10:47 AM
Wanted to give this a bump. Anyone???
Old 05-26-2013, 03:49 PM
lukc22 lukc22 is offline
Rep:17
lukc22 is on a distinguished road
im having the same issue... hopefully some one can add something here
Old 05-26-2013, 05:24 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the plug on the thermal relay on the passenger's side floorboard. There should be 5 wires in the plug. If the plug/relay (not actually a "relay" but I can't think of what it's called right now) is bad it'll switch positions because it's electronically controlled.
Old 06-02-2013, 10:30 PM
440sp 440sp is offline
Vehicle: 99 2500 4x4
Color: silver
440sp is on a distinguished road
Check the vac lines that are at the firewall on the passenger side there is a one way valve its hard to describe but those lines control the air doors for the heat and ac defroster etc........that's where I would look first they are prone to crack and the one way valve goes bad
Old 06-05-2013, 10:48 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
This could be 1 of 2 things.
1. Blend door mount is broke
2. Vac line broke/detached
For number one, you can search on Youtube for my username and heater treater. Video shows what the blend door repair is after you buy the heater Treater part (search for that).
For number two, check your vac lines. An example I recently had a couple weeks ago was after a wheeling trip. I broke my red vac line at the front axle CAD. This caused the symptoms described with the A/C. Runs fine on level, but as soon as load on the engine (hill), defrost and not cold air.
Here is picture after I purchased replacement line and I added an extension. The break was at the union elbow on the CAD, red line.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
