Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 04-17-2013, 10:05 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
Question a lil help
what is the biggest tire size i can go on the stock wheels without them rubbing? will 35's work or are 33's a better option?
Old 04-17-2013, 10:21 AM
Rep:68
i also noticed i'm geting the "death wobble" i was thinking of going to twin steering stabilizers will that stop it from doing that?
Old 04-17-2013, 11:58 AM
friendlyHP's Avatar
friendlyHP friendlyHP is offline
Vehicle: 2004 Dodge Ram AWD
Trim Level: Laramie 4x4 quadcab
friendlyHP is on a distinguished road
your truck should be able to take 35s no problem. Hell maybe even 37s. and if you are getting that wobble try a thread that isn't to extreme because the #1 cause of that is drag from highway speeds. Don't you notice the wine while cruising 65?
1992 Dodge Ram EFI 5.2 150 1996 Dodge Dakota Sport EFI 5.2 4x4
2004 Dodge Ram Laramie 4x4 (AWD)
Old 04-17-2013, 01:28 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
35"s seem to be the consensus
Twin stabalizers will just cover the problem, you need to address the root cause.
Not true, DW is caused by a very specific set of circumstances and there is a tried and true method of dealing with it.
BELOW IS TAKEN FROM A JEEP SITE I BELONG TO. I UNDERSTAND THE LABELING ON THE PICTURE MAY VIOLATE SOME RULES, BUT THE PICTURE IS CRITICAL TO THE EXPLANATION.
Though this is a write-up for Jeeps the PW suspension uses the same set-up and parts so the write-up is valid.
First, the tie rod (green) has ends that attach to a knuckle on each side. As you could imagine, if either ends of the tie rod were broken or bad, that could be a culprit for a shimmy (not Death Wobble). A common place to damage the tie rod is on the driver's side at the adjusting sleeve (in the picture, just to the right of the red swaybar link). That sleeve (maybe not the correct term for it, but you can see what I am talking about) allows the width of the tie rod to be expanded or contracted. There are threads on that end that can be damaged, causing play on that driver's side and allow an up and down, or circular play movement. Again, this would cause a shimmy, not Death Wobble.
Next, look at the drag link (purple). On one end, it attaches to the pitman arm (lavender), that attaches to the steering gear box. On the other end, the drag link attaches to the passenger side knuckle. When you turn your steering wheel, a shaft turns that goes to the steering gear box. The steering gear box turns the pitman arm, and the pitman arm pushes or pulls the drag link, which pushes or pulls the knuckle. Your steering wheel is straitened by loosening the two nuts on the sleeve/turnbuckle on the drag link and rotating the sleeve/turnbuckle to lengthen or contract the length of the drag link. If either end of the drag link is damaged, this would cause a wobble or shimmy, but not Death Wobble.
Next, look at the trackbar (aqua). It attaches to a bracket on the frame on the driver's side and to the axle on the passenger side. The purpose of the trackbar is to center the axle on the frame. With the axle centered on the frame, it provides some resistance to the steering system to allow you to turn. If there was no trackbar and you turned the steering, the whole front frame would shift. As a result, there is significant force applied to the trackbar in driving and steering.
Now, imagine that the bolts that hold the trackbar are loose in their bolt holes, or that the bolt holes are wallowed out (oval), or that the bushings at the trackbar ends are damaged, or that the bracket at the axle side has come loose because the weld has broken, or that the bushings are all twisted up because the rig has been lifted without the installer loosening the bolts and then retightened them at the new ride height. All these things would allow play in the front trackbar. When you steer or go around a corner, these loose or broken things would allow the axle to shake or slide side to side. If you hit a bump in the road, it could knock the trackbar towards the driver's side. Then, the rest of the suspension (springs, etc.) would try to bring the trackbar back to the passenger side. If you were going at any sort of speed, you could develop a kind of harmonic resonance as the axle more and more violently slide/rocked/shaked from side to side. It would feel like your whole front end was being voilently torn apart. You would have to bring your vehicle to a complete standstill to stop the harmonic resonance. This is Death Wobble.
Even one incident of violent Death Wobble related to the front trackbar can cause significant damage. The voilent harmonic resonance of the back and forth shaking is more than the trackbar bushings, bolt holes, and brackets are designed to handle. A severe Death Wobble occurance can crack or break the welds on the axle side trackbar bracket, or the bolt can wallow out the bolt hole in the bracket, or the bushing can be permanently damaged.
This is the most common source of Death Wobble because inexperienced installers either do not remove the bolt from the trackbar when they install a lift--leaving the bushing pinched in the bracket and bound up, or they do not properly torque the bolts after the lift has been installed with the tires on and the full weight of the vehicle on the ground at ride height, or (maybe the most common) they do not retorque the trackbar bolts after the first 50 miles, after every heavy wheeling trip, and at every oil change interval.
Next, look at the lower control arms (purple) and the upper control arms (light blue). In the picture, they are aftermarket arms with a heim joint on one end. However, the stock control arms have a rubber bushing at each end. When the control arms are properly torqued, the bushing is somewhat pinched in the mounting brackets on the axle and the frame. Sometimes, an installer will make the mistake of not loosening the bolts for the control arms when they install a lift. What happens sometimes is they really bind up the bushings because they are pinched/sandwiched at stock ride height, but then forced to the new lifted ride height. These bound up bushings can cause weird handling, bushing failure, and lead to Death Wobble. The proper way is to loosen the bolts, install the lift, reinstall the wheels so the suspension and jeep are at the new ride height, rock the vehicle/suspension back and forth and side to side, then re-torque the bolts to spec, then after 50 miles re-torque them to spec, then after every oil change or very heavy wheeling trip re-torque them to spec.
Improperly balanced tires, too much air in tires, bent wheels, improperly installed wheel spacers, bad tires (with separated plys), and poor alignment specs (caster, camber, and not enough toe-in) can cause wobbles and shimmies that lead to Death Wobble. However, these precipitate Death Wobble, but they are not the cause of Death Wobble.
Although not specifically identified in the picture, the ball joints that are at the top and bottom of each knuckle where it attaches to the axle C can go bad. Bad ball joints can cause shimmies, wobbles, but usually not full on Death Wobble.
Next, allthough not identified in the picture, the unit bearings can go bad and be a cause of shimmy and wobble, but not Death Wobble.
Hope this helps--assuming you read it all.
Death Wobble is no mystery.
The reason that the steering stabilizer masks it is that it can absorb some of the side to side voilent harmonics of a loose trackbar or damaged mounts. However, this masking is dangerous because it will not prevent the eventual failure of trackbar bracket welds and bolt holes from trackbar Death Wobble.
It is extremely important to immediately diagnose and fix Death Wobble.
Even one episode of DW can damage other components.
Multiple episodes of DW are almost guaranteed to damage other components.
Multiple episodes will often damage your:
  • ball joints
  • tie rod ends--including the adjusting sleeve end on the driver side
  • trackbar bushings
  • trackbar bracket bolt holes
  • steering sector shaft (where the pitman arm attaches to the steering box)
  • steering stabilizer
  • front lower control arm bracket bolt holes
  • unit bearings
  • trackbar bracket welds
  • drag link ends
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 04-17-2013, 10:23 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
http://www.kevinsoffroad.com/dodge-w...-causes-cures/
"dodge Death Wobble"
Smile even if its a little creepy
Old 04-17-2013, 10:25 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
Nice write up battle rattle... reps to ya
Old 04-21-2013, 06:27 AM
Rep:68
thanks for the info i am getting a twin steering stabilizer from skyjacker monday but i will be thoroughly inspecting the whole front end for the cause. i know the track bar is less than 2 months old. but i also know new parts can be bad out of the box as well. thanks for the help guys.
Old 04-21-2013, 01:54 PM
Rep:68
oh yea also i don't have any whine at all while doing highway speeds.
Old 04-21-2013, 11:51 PM
Rep:68
the main reason i am changing the steering stabilizer is because mine has leaked out all the oil. i'm sure with it having done that it isn't helping the death wobble issue i got. i checked the whole front end and it's all tight and good. nothing is loose or worn that could find anywhere. the only thing i found was the steering stabilizer is shot.
Old 04-22-2013, 09:01 AM
Rep:256
Nothing loose or worn doesnt mean someithing isnt worn out. Whats your toe, caster? How are your ball joints?
Keep in mind when we put things together we gennerally go the GnT method (Good n Tight). That doesnt work on suspension. Your trackbar bolts need to be 140ft/lbs, doesnt matter how big you are, that is hard to do with normal hand tools.
Did you check your TB mounting holes for roundness?
Remeber a cursory glance, even putting your hands on nuts and bolts wont tell you if something is wrong.
I say all this because I constantly hear Steering Stabalizer. On a properly set up suspension a SS is not necassary. It serves to dampen only the harshest bump steer inpunts (think droping into a rut at freeway speed).
