Old 04-17-2013, 02:34 PM
FilthyDog's Avatar
FilthyDog FilthyDog is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
FilthyDog is on a distinguished road
Red face Big Truck Small Garage
My truck started blowing white smoke a few weeks ago. I'm a poor mechanic at best and was immediately concerned that the Hughes Plenum fix or headers I installed caused the problem.
As it turns out, it was not my work but blown head gaskets.
I have the heads removed and am taking them to the machine shop for a valve job.
Over the next few weeks I'll be posting pics of the rebuild.
-Filth
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
Old 04-17-2013, 02:42 PM
FilthyDog's Avatar
Here's a few pics of the work so Far. Does anyone have any advice on cleaning the block and the pistons?
Old 04-18-2013, 01:57 PM
FilthyDog's Avatar
I dropped the heads off at Gunn Automotive in Denver this morning. I spoke with the owner (Phil Gunn) and his employee Keath. They were both very friendly and professional. Which, after talking to other machine shops in the front range, was a breath of fresh air.
They are going to clean and inspect, resurface, and replace any worn out guides. As well as replace the guide seals. The heads should be ready to be picked up in 4 or 5 days.
Old 04-18-2013, 02:04 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
no port and polish?
2005 Dodge NSRT-4
Old 04-18-2013, 07:23 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Rep:326
That sucks... How many miles are on it?
Old 04-19-2013, 04:40 PM
MACKEYAUTOREPAIR MACKEYAUTOREPAIR is offline
Vehicle: 1999 DODOGE RAM2500
Trim Level: LARAMIE SLT
Color: BLUE
MACKEYAUTOREPAIR is on a distinguished road
DO NOT use any sort of abrasive on the block surface. It's not needed, and any abrasive, bristle discs, scotch brie, anything, will get into the oiling system and take out bearings. Every maker has a TSB on it, and I learned it the hard way. The best thing is a carbide scraper. I have one that's 3 inches wide, and it's about 1/8'' thick. I then use a razor blade around the dowel pins, or better yet, pull them out. I don't know where to tell you to get the scraper, though, mine came from Goodson Supply and they are an engine overhaul wholesaler. A razor blade will work, it just tedious. You're pistons aren't that bad, but if you want to clean them, the best stuff is Motorvac solution. you just pour it in to cover them overnight, and they will wipe clean. It also seeps down and cleans the rings. If you can't find any, carb soak is the next best. Make sure to chase the head bolts threads with a tap, then shoot some brake clean into them, hold a rag over the top, and blow them out with air. I believe those are dry holes, so a little oil on the threads and under the bolt heads, and you're ready.
Old 04-23-2013, 02:11 PM
FilthyDog's Avatar
I'm not having the heads ported and polished. I had to draw the line somewhere.
The Truck has 131k on it and I'm going to try to make it last another 131k.
I did spring for a Hughes FI intake. Hughes was out of modified throttle bodies, I plan check back with them every now and then and slap that on when there's one available.
I'll be working on the Truck this weekend, so I should have some new pics to post soon.
Old 04-30-2013, 11:17 PM
studda studda is offline
Vehicle: 2001 Dodge Ram Sport
studda is on a distinguished road
Port and polish isn't that hard to do yourself. All you need is a good die grinder or even a dremel will probably work. I've done it on my drag car heads and could definitely notice a difference. The trick is, don't polish the intake ports but give them a straighter shot to the valves. Too polished and the fuel will gather on the walls and not stay in suspension. Get the exhaust as polished and straight of shot out to the headers/manifolds as possible.
Old 04-30-2013, 11:31 PM
I was scared the first time I ported heads but if you never try it you will always be afraid to. I'm sure you can find specific areas to focus on for the exact heads you have and you will be glad you did. I didn't go in blind and just start grinding. I did research and used other people's proven methods.
Old 05-02-2013, 01:18 PM
FilthyDog's Avatar
Thanks for the port and polish advice, but the heads are back on the truck.
head gasket, hughes fi, no bus, plenum
