Old 04-17-2013, 03:22 PM
jpinthewoods jpinthewoods is offline
Vehicle: 1999 ram 1500
Color: red
jpinthewoods is on a distinguished road
Default front axle will not engage
1999 ram 5.9 liter the np231 trans case works however the indicator light for 4wd and the front axle will not engage i have found a what i believe is a vaccum lune from the actuator ontop of the axle is currently just hanging in the engine bay looks like it has been cut and i have no idea where it supposed to go i just bought the truck and i has had a rough life many parts have been removed or replaced long before me so i am in the process of fixing what whoever did wrong or halfa@@
Old 04-21-2013, 06:11 PM
MACKEYAUTOREPAIR MACKEYAUTOREPAIR is offline
Vehicle: 1999 DODOGE RAM2500
Trim Level: LARAMIE SLT
Color: BLUE
MACKEYAUTOREPAIR is on a distinguished road
From the actuator on the t case, there's 4 vacuum lines. 2 go to the front right axle to couple it when you shift into 4wd. 1 is a vent, and one goes up to the engine for vacuum supply. I suspect thats the one youre missing, if I get a chance ill look at mine to see where it hooks up. It has a check valve, and that may be where iy unhooked, so if you can find that it will help.
Old 05-28-2013, 08:02 PM
SScott's Avatar
SScott SScott is offline
Vehicle: 2001 Ram 2500 4X4
Rep:19
SScott is on a distinguished road
Any updates or place to get the vacuum diagram? Thanks!
Old 06-05-2013, 09:28 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Here is a picture where I extended my vac lines on the front axle. This view is looking up towards the passenger fender.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
