Get more info using VIN - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-17-2013, 06:33 PM
Ristar15 Ristar15 is offline
Vehicle: 2016 RAM 1500
Color: Blue
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Ristar15 is on a distinguished road
Default Get more info using VIN
Im looking at a used 2007 and have the VIN. is there a way to use that to find original specs of the vehicle? Specifically if it is quad/crew (pretty sure quad), bed length, and trim level (hint at ST/SLT)
Old 04-17-2013, 09:49 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
I want to say the SLT has stainless/chrome bumpers and the ST has black plastic. Quad cab/ crew is fairly easy just by looking because the quads look more like half doors and the crew looks almost the same size as the front.. Bed.. There is 5'7, 6'4, 8. The only way you can really get much info off the vin would most likely have to be through a build sheet, which requires ownership.
Just to give you an idea of what the quad cab , 6'4 box looks like.. Heres my truck.. 08, so identical body style.
IG:@briley59
Old 04-18-2013, 08:58 AM
Lawdog4817's Avatar
Lawdog4817 Lawdog4817 is offline
Vehicle: 2015 "Dark Side" RAM 1500
Rep:29
Lawdog4817 is on a distinguished road
^^^^ What he said...Also you might want to check with Carfax.
Old 04-18-2013, 09:30 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Agreed. Unless you can talk someone at a dealership into accessing the build sheet for you, you probably aren't going to get this info from the VIN.
As was already said though, all of those things can be very easily determined by seeing the vehicle. If that isn't possible for some reason I would contact the seller and make them obtain a build sheet and send it to you. If they really want to sell it, they will. It doesn't cost anything.
Old 04-18-2013, 10:49 AM
Trim Level: SXT 4x4
Rep:2826
I was also going to say Carfax, but I didn't know how much it would cost and if he is just looking for mainly body measurements, isn't to hard to see just from the eye.
If the truck is as long as a bus.. then it is long box crew cab
IG:@briley59
Old 04-18-2013, 11:04 AM
Color: Blue
Thanks, from pictures it looks like an extended cab 6 ft bed but the dealer told my dad it was crewcab 8 ft... It is a used car dealers so they always get confused with extended vs crew and rim level it seems.
What's your opinion of 2007 Cummins 2500s? Any common issues with them?
Its got about 80k miles and my dad said its pretty clean. Carfax says 1 accident but no damage. Do 07s have emissions equipment? Someone told my dad this one is reported to get 20 mpg.
Old 04-18-2013, 11:29 AM
Trim Level: SXT 4x4
Rep:2826
Yeah with Rams it can be tricky at first, seeing as other companys typically had/ have suicide doors for the quads, but I think dodge eliminated that with the 3rd gen.. And yeah used dealerships typically do have an issue with knowing what they are actually selling. I don't know much about the 07 cummins because I beleive that is when they switched from the famous 5.9L to the 6.7L with the emissions equipment, so first year engine there is probably some kinks and issues like usual.. I know that you will be able to find threads with reviews about it on here with some research.. I found this on google which may have some benefit, hopefully don't get in trouble for posting this. Good luck with your hunting, Cummins and Rams in general are amazing trucks.
http://autos.msn.com/research/vip/ov...104551#VIP_TAB
IG:@briley59
Old 04-18-2013, 11:41 AM
Color: Blue
It's listed as 2007 5.9l Cummins.
My main gripe is I'd like a crew cab long box. Im still considering it due to price and need vs wants...
Ugh anyone just want to buy me a truck? ;-)
Old 04-18-2013, 11:49 AM
Kcbigbadram's Avatar
Vehicle: 2007 1500
Trim Level: Big horn
Color: Inferno red
Rep:503
im pretty sure there was only quad cab or mega cab in the 3rd gen right?
Old 04-18-2013, 11:52 AM
Color: Blue
I was wondering that, but it sounded stupid in my head so i ignored the though. Hearing someone else say it makes it sound more reasonable.
