Old 04-18-2013, 10:43 AM
2012Sport's Avatar
2012Sport 2012Sport is offline
Vehicle: 2014 Ram 1500
Rep:39
2012Sport is on a distinguished road
Default Bilstein 5100 TGC 1.50 rear spacer and RCX 1.25 body lift going on Sunday
So the parts are in and I found a day. I will be doing this on my own on Sunday so any pointers are greatly appreciated. I did find a few write ups that I'm sure will help it go smoother. I will get some before shots and after shots for sure. I had hoped to document it all for a write up, but now that I'm doing it solo it just isn't going to work out. Truck only has about 3500 miles so hopefully( I better not) dont run into any corroded bolts.
Come to think of it I dont have any pics up from when i got it...or what it is...wow I'm slacking!
2014 White Ram 1500 Big Horn. Halogen OEM headlights.
Old 04-18-2013, 10:46 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
as far as the bilsteins go:
here is the one that would be helpful if u had an older truck and the bushing might be seized...you shouldnt have that problem..but I'll still give you the link.
http://www.ramforumz.com/showthread....ght=strut+bolt
http://dodge forum.c om/forum/4th-gen-ram-tech/312121-bilstein-5100-diy-install-pic-heavy.html
and this one talks about removing the cap on the old shock so u can remove the spring seat
http://www.ramforumz.com/showthread.php?t=89526
you need to rent a spring compressor from you local autoparts store. you put a deposit down and get it back when you return it. Just be safe and smart. A set of through sockets came in handy for me
http://www.lowes.com/pd_379758-22328...7C1&facetInfo=
Old 04-18-2013, 11:23 AM
2012Sport's Avatar
Rep:39
I just happened to get a set of those sockets for christmas that I haven't used yet!
Thanks for the other links as well.
Old 04-18-2013, 11:27 AM
Rep:1900
Well they will be very useful. No problem. Can't wait to see the pics.
Old 04-18-2013, 10:47 PM
2012Sport's Avatar
Rep:39
Ok. I just read some post where a guy stated he did a body lift and when he was done the cab was off center...Is that even possible? Now I'm a little worried doing it myself.
Old 04-19-2013, 07:33 AM
Rep:1900
yes it is possible. but if you take your time and adjust everything before tightening everything up, then you'll be fine.
