Old 04-18-2013, 11:10 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
I paid $380 for the Truxx 2" leveling kit install ands alignment on my 06 2500 4x4
Old 04-19-2013, 12:34 AM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
Ok so the $440 is not to far off. Maybe I'll try the install myself.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff coverhttp://i29.photobucket.com/albums/c2...pstcriuhl7.jpg
Old 04-20-2013, 07:51 AM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Do the install yourself, it's fairly easy. Just need a strut spring compressor. Otherwise piece of cake. Save yourself some coin. Then alignment for 100 and your done!!
Vararam CAI, Moes 87mm, flowmaster ,20x9 DC gun metals, 325/60/20 Terra's , bilsteins set at 2.1 , access tonneau, raptor W2W nerfs, AVS ventvizors , tints.........
Proud member of LOCAL 361 IRONWORKERS
Old 04-20-2013, 09:22 AM
Blatant Blatant is offline
Vehicle: 2013 Ram 1500 quad, 4x4, Hemi
Color: True Blue
Blatant is on a distinguished road
You don't need a spring compressor to install a front level on a Ram. I've installed levels on a few trucks. The Hellbent Steel 2-inch level I installed on my '13 Ram took about 90 minutes from pulling into my garage to pulling out.
Very pleased with the HBS kit and it's pretty cheap. They all tell you that you need an alignment and you do. That said, I drove my truck for several weeks without. No unusual handling or tire wear; when I did get the alignment, the numbers weren't far off and honestly I probably could've done without it.
Old 04-20-2013, 04:53 PM
ckage83 ckage83 is offline
ckage83 is on a distinguished road
That price isn't bad. After it is aligned I'd reccomend going back to the shop after 100 miles and have them either verify it is still aligned or atleast retorque everything. I had a nut come loose on my tie rod and it almost killed me.
Old 04-22-2013, 10:18 AM
HenrysRam's Avatar
HenrysRam HenrysRam is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: 4x4 Quad cab Express
HenrysRam is on a distinguished road
I paid $80 for my 2.5" Hell Bent Steel kit and brought it to a local shop that charged $213 for install and alignment, good Work too. $440 sound like a lot to me compared to $293...
"It'll stop hurtin' when the pain goes away"
Old 05-04-2013, 01:06 AM
nfd538's Avatar
Rep:16
Ok some of you sre saying coil spring compressor and others are saying strut compressor which one?
Old 05-04-2013, 01:20 AM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
They're the same thing, you don't need to compress your spring though. The level kit bolts to the top of the strut, it's just a spacer. $440 is a ton of $$, buy the kit yourself $80-100, install it, then get an alignment($100)
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 05-04-2013, 01:30 AM
nfd538's Avatar
Rep:16
Yes I do need a spring compressor, I got the Bilsteins not a coil spacer. I hear its easy but I never did this don't want to kill myself
Old 05-04-2013, 02:36 AM
Rep:21
Even better, I just installed bilsteins on my truck last weekend. I bought a spring compresser for $65. I set them at 2.8 which I found was too high, so I lowered them to 2.1 lol. Not a hard job, just take your time compressing that spring. Air impact is also good to have.
