Any tips for debadge front and rear emblem 2013 Ram? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-18-2013, 10:29 AM
bolo1g2 bolo1g2 is offline
Vehicle: 2017 Ram 2500 Crew Cab 6.4L H
Trim Level: Tradesman Outdoor
Rep:19
bolo1g2 is on a distinguished road
Default Any tips for debadge front and rear emblem 2013 Ram?
Hello, any tips for removing those badges? Do they just pull off? I noticed there are pins in both the front and rear badges? Just wondering if anyone might be able to shed some light on the process? I plan on removing mine this weekend, but wanted to hear some experiences?
Old 04-18-2013, 11:24 AM
Rep:19
I've searched through the forums and gotten plenty of tips on the rears, but the front people keep mentioning clips? For those that did this, did you just heat up the emblem, peel it off, then unclip as you pried? Or did the clips break?
Old 04-18-2013, 11:48 AM
TSINND's Avatar
TSINND TSINND is offline
Vehicle: 2014 Ram 1500
Rep:28
TSINND is on a distinguished road
front is just clipped on, remove upper shroud and unclip it from behind. The rear I heated it up slightly with a heatgun and use fishing line. Worked great.
Old 04-18-2013, 11:56 AM
Rep:19
Thanks. I'll try it and do some pics this weekend.
Old 04-20-2013, 04:47 PM
Rep:19
So for anyone doing this, for the front badge it's 4 clips and a mini piece of adhesive in the center of the badge. So work the clips off, pull and it should come right off. For the rear, just heat it with a heat gun and pull. you can use fishing line, but there are alignment pins in a couple spots that will stop the string.
