Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-19-2013, 12:58 PM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
Default Roof basket your truck? click here, done!
So your looking to put a baket on your roof? well here is all the info you need to complete it.
you are going to have to order a set of cross bars that fit your truck. I went with Rhino areo blade corss bars. there are many others that will fit.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Then you will need a basket. I went with the Surco 50x50 it fits well and mounts almost perfectly with hte Rhino cross bars. There are a slew of other baskets availible, but not sure on fitment with corss bars.
The Rhino bars way exceeded my expectations, they are well build and sturdy. the directions are a wee bit confusing but by looking at pictures i was able to figure it out.
Install on the truck was not that bad, it would have been easier and i would have one less scratch in my roof.
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 04-19-2013, 01:00 PM
Rep:112
Install of the basket was a little more difficult, The basket comes with bars to install with, throw them away, they make the basket sit another 2 inches off the truck and rattle like crazy, make sure you keep all the hardware though.
You may have to adjust the cross bars, me I liked my bar placement so adjusted the attachement holes on the basket. On the rear cross bar remove hte end caps and pull the trim out of the top rail, slide 3 mounts in the rail upside down, if you place small side up the screws dont reach and they sit angled when tightened. Screw the screws into mounts, do not tighten, center your basket, or place where you would like it. Using a sharpie mark the rubber on the front cross bar on the sides of the basket floor so you can trim it also mark the basket mounts in hte middle of the bar so you can drill holes.
Old 04-19-2013, 01:11 PM
Rep:112
All mounted and secure you can start adding your extras like hi-lift mounts, spare tire mount, tool boxes, axe/shovel mount.
Old 04-19-2013, 01:51 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
wow that is awesome! great write up! all said and done, how much did it set you nback if you dont mind me asking? rep points for the great wrte up
Old 04-19-2013, 02:22 PM
Rep:112
$550.00 for the crossbars and basket.
I will take some more pis of the mounting to the corss bars later and add those.
Old 04-21-2013, 08:29 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
That looks sweet.....Nicely done.....
Old 05-16-2013, 11:35 AM
Wizza's Avatar
Wizza Wizza is offline
Vehicle: 2012 Ram CTD 2500 4X4 Laramie
Color: White/Silver
Rep:119
Wizza will become famous soon enoughWizza will become famous soon enough
Very sharp setup....will bookmark this one.
http://ramforumz.com/picture.php?alb...ictureid=12320
S&B Intake, MBRP Cool Duals exhaust, 4" MOPAR lift, NFab step bar, Anthem Offroad Defenders 20X9, Toyo AT II 295/65-20, V-LED backup frame, LED reverse lights
Old 05-16-2013, 02:47 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Good looking setup. Are you planning to add off-road lights to the front of the basket?
Old 05-16-2013, 03:25 PM
Rep:112
Just put a set of KC's up there last week, just have to figure out the wire route then ill be adding a few more sets.
i have a 6 wire trailer wiring cable, weatherproof gromet nad some other stuff coming so i can try and figure out how to get everything working correctly.
also already have the mopar aux switch and everything needed to wire that up.
Old 05-16-2013, 03:48 PM
Rep:2616
Great Pix & write up
Where is your KAYAK, etc.
