Old 09-09-2012, 09:49 AM
Phillylunatics20 Phillylunatics20 is offline
Vehicle: 2005 Dodge Ram
Phillylunatics20 is on a distinguished road
Default Need to remove license plate light covers?
hey guys im not sure on how to remove the license plate light covers... i dont wanna break them but they need to me cleaned they are very yellow. thanks
Old 09-09-2012, 08:14 PM
Rep:28
Yeah, mine are too. Haven't looked to see what it takes to get them off though. If I do before someone posts, I'll reply.
Old 09-10-2012, 12:51 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Mine were doing the same thing so I treated them to some Nite Shades. I don't think you will be able to clean the yellow oxidation off of them. Check my Nite Shades thread in the Exterior mods forum.
As for getting them out, I don't know that the lens actually comes out of the plastic housing. I tried to pry them out and to push them out from the back but they weren't budging and one even looked like it might start cracking. I removed the entire little housing from the bumper and taped off the lens to apply the Nite Shades and clear. The housing is very easy to remove. There is a metal clip on the back side of the bumper. You can feel it without getting under there but you might want to lay eyes on it to see exactly how it comes off. It pretty much just slides out, then twist and remove the light and socket, and the housing and lens comes free. It will be very obvious when you look at it. Hope this helps.
Old 09-10-2012, 01:25 AM
Rep:28
To actually clean the oxidation, you have to sand down to new plastic. But, if there's no way to get the actual lens out of the housing, that might make that hard...
Old 09-10-2012, 03:09 AM
Rep:367
Yep, that is the problem. It may very well come out but when I started to pry on mine it started to come apart. It was almost like the lens was dry rotted and softened. You know how some plastic takes on a crumbly, powdery quality after it's been in the sun too long? I looked the part up once and it came as a whole....the lens and the plastic housing/trim around it. Seems like they were about $30-40 each.
Old 04-20-2013, 07:26 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Any idea what these part #'s are? I'm putting led's in mine and for whatever reason I got clumsy and the bulbs popped out on both while installing...and are now trapped int he housing. I think I know how to remove the housing but if mine are bad I may get 2 new ones.
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 04-20-2013, 11:31 PM
Rep:367
It appears the left lamp is Mopar # 55077291AF.
http://www.ebay.com/itm/NEW-Dodge-Ra...2eb330&vxp=mtr
And the right lamp is 55077292AF.
http://www.ebay.com/itm/NEW-Dodge-Ra...2ebe99&vxp=mtr
