Old 04-21-2013, 09:54 AM
jd2002wtf jd2002wtf is offline
Vehicle: 2002 ram 1500
Trim Level: cheap
jd2002wtf is on a distinguished road
Default engine code help
Hi all,2002 4.7 ram
recently had to rebuild my motor and now its throwing codes,any advice welcome
P0551,power steering pressure sensor circuit range performance?
The power steering sounds like its low on fluid(moaning on turning)
Its full.
P0445,evap emission cont sys purge control valve circuit shorted?
Any advice welcome.
P01683?
No clue
Old 04-21-2013, 05:12 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Both of those parts need to be replaced. There's no but or explanation really. The P1683 its an internal PCM failure so what you wanna do before you replace anything is Disconnect your battery positive and negative wait then minutes and with everything disconnect turn your key to the on position for about a minute then back off and reconnect the battery and take a ride for at least 20 mins to let the pcm relearn and see if the problem continues with the pcm. If the problem continue start looking into getting a new pcm or used depending on your budget. hope it helps
