ok another issue on my pw. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 04-21-2013, 09:56 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
Unhappy ok another issue on my pw.
ok guys both pinion seals are leaking. are they held in by the retainer nut or do i need a puller to get them out? and what do you guys recommend for fluid in the diffs?
Old 04-22-2013, 09:04 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
If its just the pinion seals, you can pull off the yoke and remove the old seals with a screwdriver or a puller. Clean the inner lip and tap the new ones in gently. As for fluid, go with the factory recomended weight and get good old dino. Synth has some good bennefits but for some reason doesnt transfer heat as well. Good old dino will be fine in a diff application. (75-140 if I remeber correctly).
Just Got it, Give me time!
Old 04-22-2013, 10:18 AM
Rep:68
cool thanks. i guess i should have been more specific i meant do i need a puller for the yoke after i take off the retainer nut
Old 04-22-2013, 08:28 PM
Color: Granite
Rep:286
I have never needed a puller for them. Pull the pinion nut and washer and give them some good whacks with a hammer on the side. This has always worked for me, but if yours are stuborn a puller may be necassary.
