Old 10-08-2009, 11:51 PM
CosmicVagabond CosmicVagabond is offline
Vehicle: 2009 Dodge Ram 1500 Crew
Color: Austin Tan
Rep:70
CosmicVagabond will become famous soon enough
Default Integrated trailer brake controller?
Hi folks,
I read on the 09 forum that the 10's will have an optional trailer brake controller. Do you think that this might be able to be retrofit to a 09?
Old 10-09-2009, 12:13 AM
I push the skinny pedal
Rep:3308
It might, but there are also plenty of aftermarket trailer brake controllers that are really good and would probably be easier to install. Unless you want a clean look and not have the controller just hanging below your console of course.
Kurtis
Old 10-15-2009, 12:12 AM
Color: Austin Tan
Rep:70
I've done some more reading and saw where the factory brake controller will display through the EVIC. This would be a neat touch an aftermarket controller wouldn't do. Anyone else have any ideas if this could be retrofit to an '09? Anybody have any ideas who might know? Not sure if the dealer's service dept would know...
Old 10-15-2009, 12:41 AM
Rep:3308
I doubt a dealer could help, unless it bolts on stock they don't touch much. Maybe Tom can pitch in or someone with some electrical know-how.
Kurtis
Old 10-18-2009, 07:45 PM
Aussieincalgary's Avatar
Aussieincalgary Aussieincalgary is offline
Vehicle: 2009 Dodge Ram Crewcab
Aussieincalgary is on a distinguished road
Yup, on a lot of issues like this (add on's) the parts guys aren't much help.
I found the dealer wanted a hundred dollars more for the "Factory"!!!! controller than the after market version with the adaptor plug that plugs stright into the connector under the left side of the dash. I just wish I could put the controller somewhere so it doesn't touch my leg at times, but not make me drill holes all over the dash.
If the integrated controller works then that WOULD be cool.
Old 10-19-2009, 01:16 PM
Color: Austin Tan
Rep:70
Hey Aussie,
Look on the lower part of your dash area where your left knee is. There should be a small cubby hole there. I had the dealer cut out the back of that compartment and slip my aftermarket controller through that. The controller is then recessed into the dash and central to the plug in. If I ever want to restore that cubby it's very cheap just to buy that small part and it will be good as new. If your controller will fit that area it's a good option.
Old 10-19-2009, 08:42 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
I installed my controller....I could not come to drilling holes in the dash. I have a real long lead that plugged into the OEM connection. I tuck the wires up under the dash and when I need the controller I pull them out and hook it up. it lays on the cup holder while
I tow.
Old 10-20-2009, 10:33 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
who makes the 'Factory" controller? I was going to get it but forgot to have it added on.. have a p/n by chance?
Old 11-04-2009, 09:58 PM
Rep:44
this is off the 2010 power wagon.. wonder if it will be plug and play for the '09
The '10 also has power lock for the gate which will work on the 09's
Old 11-04-2009, 10:17 PM
Rep:44
Information on the TBC is also displayed on the EVIC... Not sure if this is available on the 1500's but it is on the 2500 and up..
