Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Daytona
Old 04-23-2013, 10:18 AM
joebar61 joebar61 is offline
Vehicle: 2005 dodge ram 1500 daytona
Trim Level: daytona slt
Color: bright silver
joebar61 is on a distinguished road
Default caliper paint
anyone use a brush on old caliper/ new rotor paint any tips or brands in gloss black thanks in advance
Old 04-23-2013, 07:09 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
On my last car I first used brush on paint on my calipers. It ended up getting chipped very easily and then started flaking off. If you're going to do it, do it right. Take them off the truck, clean them up proper, put a good coat of primer on, then a couple coats of caliper paint, then a couple coats of clear.
I picked up my paint in Lordco up here in Canada. I forget what brand it was but it was in a taller black can with a brake disc on the front made specifically for calipers. It worked very well. Check out what your local auto shop has. They should have some good caliper paint in stock.
Old 04-23-2013, 07:25 PM
Thank you Brandon
Old 05-05-2013, 08:51 PM
Shug's Avatar
Shug Shug is offline
Shug is on a distinguished road
I used Dupli-Color with ceramic, brush on in red. Been on 5 years and still looks great. The main thing is to clean the calipers good. I applied the paint and let it dry for 24hrs. then I drove my truck for a week then rinsed them off and applied a high heat clear
Old 05-05-2013, 08:57 PM
dodgert's Avatar
dodgert dodgert is online now
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Your best bet clean them really good then hit them with header paint then use the brush on it will not chip as bad.
Old 05-05-2013, 09:03 PM
Thanks guys i goy dupicolor brush on blk with ceramic im going to then cleam again
