Old 04-23-2013, 08:26 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
Default 2010 Ram Running Bar replacement
I hope someone can help me out here.
A friend just emailed me tonight because Dodge replaced her Factory step bars with new ones, but she thinks they are on backwards...
I dont have the step bars on my truck, so im hoping someone can help. FWIW its a 2010 Larime CC. here are the pics.
She believes that the curved end of the bars should be facing the rear of the vehicle, yet hers are installed facing the front.
thanks for looking.
Jeff
rear of truck
front of truck (notice curve of step bar).
Old 04-24-2013, 12:02 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Yup. They're put on the wrong sides. Switch em left-right.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 04-28-2013, 05:29 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
Bad info.
The curved part of the step goes forward. Look at the brackets. They only go onto the bars one place and are not evenly spaced. The body mounts are also only in one place. So they can only be installed one way, the correct way. (on a QC or CC)
To ease your mind, look at the install instructions below. You will see the curve to the front as well as the larger distance from the bracket to the end of the bar in the front. The rear bracket almost to the rear of the bar. Same as the pictures posted above.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 04-28-2013, 05:38 PM
Outlaw's Avatar
Color: Bright white
Rep:435
Well then I must be wrong.
[/CENTER]
Old 04-28-2013, 07:34 PM
Rep:910
well she had the delaer change them regardless if they were on wrong and now shes happy...
she also felt that the plastic step part didnt line up with the doors....
anyow thanks to all those who helped...
Old 04-28-2013, 07:46 PM
topgun's Avatar
Rep:71
How did they switch them? The bolt holes are not symetrical? They must of drilled new holes in the bars for the center bracket.
Old 04-28-2013, 07:49 PM
Rep:910
good question..ill look tomorrow at work...
i honestly dont think they are MOPAR original parts, so maybe they can go on both ways, but who knows...
Old 04-29-2013, 11:43 AM
jayace's Avatar
jayace jayace is offline
Vehicle: 2010 Ram 1500 Laramie 4x4 Crew
Color: Blue on Gray
jayace is on a distinguished road
I'm curious, why did the dealer replace them? I have one that looks like some of the finish has come off and is starting to corrode. The dealer told me last week that he needed to send pictures to Chrysler Canada before they can do anything so I'm now waiting to hear back.
Old 04-29-2013, 06:29 PM
Rep:910
im not too sure. she went in and complained, and the dealer replaced without batting an eye...
also she bought the truck used from a dodge dealer...
