Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-23-2013, 08:05 PM
Bohica Bohica is offline
Vehicle: 2004 Dodge Ram
Trim Level: Laramie SLT
Color: Atlantic Blue Pearlcoat
Bohica is on a distinguished road
Default CV axle install 1/8-inch away;100% stumped!
I removed the RH CV axle in my 2004 to replace the hub-bearing assembly and steering knuckle. Those tasks are complete. My boggle now is that I cannot get the axle installed.
I used a foot-long spreader clamp to compress the axle. I placed one end of the spreader on the diff-case and the other end on the inboard side of the axle. Using this approach, I'm able to compress the axle to where the female end of the shaft is 1/8-inch away from slipping back on the male-spline shaft coming out of the differential.
I watched several videos. Each shows the process as a simple deal;
1. Slide axle in to hub
2. Wiggle female end over diff-shaft
Right!
I'm an 1/8-inch away from getting the axle installed. Seriously. What can I do to gain the necessary clearance? Can I tap the differential shaft a little bit to buy that clearance?
File Type: jpg Dodge 3rd Gen Forums CV install post - forum resize.jpg (56.2 KB, 15 views)
Old 04-24-2013, 08:08 AM
Rep:1885
Use a soft faced mallet to drive the axle the rest of the way onto the shaft.
Old 05-01-2013, 08:56 AM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
If the spindle and lower control arm are dropped then that could be why it wont reach. also if you loosen the nut holding the axle to the hub then you should be able to get the extra play that you need.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
