Old 04-25-2013, 05:20 AM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Trim Level: Laramie Longhorn
Rep:61
UpToNoGood will become famous soon enough
I like the idea of the larger Nitto Terra Grappler for my truck, but can't see myself getting rid of 4 tires with plenty of life in them.
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 04-25-2013, 08:32 AM
ramaries ramaries is offline
Vehicle: 2013 Ram
Trim Level: Outdoorsman
Color: Blue
Rep:39
ramaries is on a distinguished road
Originally Posted by DrAudio View Post
I'm in Batesville ...
I am about an hour from you.
I am running some Nitto Terre Grapplers on a Ford truck right now and had some Duratracs before then (in 18"). The Nittos give a smoother ride and are a bit less noisy. But really, I think I liked the duratracs better and will probably go with those on a new Ram. If you want just hwy consider the michelins. Many tires wear funny with cupping so be careful and research the ones you are considering if you want to get good miles from them. The Duratracs I had I sold at 45,000 miles and they still had good tread with no irregular wear whatsoever. I don't know about the Nitto but it appears they have softer rubber and that I won't get the miles I got from the Duratracs.
Old 04-25-2013, 08:50 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
I have Nitto Dura Grappler tires here some info on it the E rated tires is what helps you maintain a stiffer side wall while towing and are 10 ply.
these tires are great I'll don't think I'll need a different tire as long as I have this truck. Hope this helps
http://www.nittotire.com/Tire/duragrappler
(The Dura Grappler® is a highway terrain tire that provides a combination of tread life and ride comfort. The Dura Grappler® is suitable for a wide variety of light trucks, SUVs and CUVs. It is also available in popular 'E' load range, heavy-duty LT sizes for today's demanding diesel trucks. All P-Metric sizes in the Dura Grappler® line come with a 5-rib pattern. Whether you're working on a construction site or towing your toys, the Dura Grappler® was designed to meet your needs.)
(LT Tires with an "E" load range have a 10-ply rating.)
Old 04-25-2013, 10:01 AM
CLOTAGAMES CLOTAGAMES is offline
Vehicle: 2015 RAM 1500 CREW laramie 6'4
Trim Level: LARAMIE
Color: WHITE OVER SILVER
CLOTAGAMES is on a distinguished road
Sticking with stock wheels
Old 04-25-2013, 05:39 PM
Trim Level: LARAMIE
Default Cooper zeon ltz 275/65/r20 with air suspension
Just put on today-will just rub inner plastic when in enter exit height. Ride nice. 1" taller than standard tires. Pictures show at all 4 ride heights.
Old 04-25-2013, 07:27 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Vehicle: 2014 6.4 Hemi; traded 2013 CTD
Trim Level: Laramie Crew 4x4
Rep:139
Originally Posted by CLOTAGAMES View Post
Attachment 35360
Attachment 35361
Attachment 35362
Attachment 35363
Attachment 35364
Attachment 35369
Awesome pics! Do they rub at full lock, or all the time? Curious if your stock tires rubbed in same place. Can you trim the plastic piece, or is it concerning enough to do that?
2014 2500 Laramie Crew 6.4 Hemi, 4.10 axle
2013 RAM 2500 Laramie Longhorn, Cummins, Western Brown (traded)
Old 04-25-2013, 07:29 PM
HorseMan's Avatar
Rep:139
How are the Terra Grapplers in the rain? I've heard varying degrees of copmlaints, but also many good things. And are you running LT tires or P rated tires?
Old 04-25-2013, 09:42 PM
Trim Level: LARAMIE
Only rub at lowest enter/exit height. Just barely touch plastic inner front fender liner. I have Nitto Terra Grapplers on my jeep and I think these Coopers are quieter than the Nittos. Have run Goodyear Duratracs before. These remind me of them. These are aggressive looking tires. Thumbs up so far
Old 04-25-2013, 10:01 PM
HorseMan's Avatar
Rep:139
Thanks! I assume they only rub at full lock?
Old 04-26-2013, 12:56 AM
HorseMan's Avatar
Rep:139
Can you post up some pics?
