Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Place your Ad Here!
Old 05-20-2013, 11:42 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
Originally Posted by Chris65 View Post
With code P0406 is not necessary the valve. It just tells you that the valve is on high end. This can be the result of air intake problems like wrong signal from sensors like maf, map or temp.
Check it first or better, clear error memory and set readiness codes on zero and drive. When it comes back, Check what I said. With this code the light should come on anyway and you will notice it. Just change the valve if you find nothing else and please, would be great if you would keep me in the loop. I'm very interested, what the results are!
Thanks.
I will clear this evening and monitor...will also keep you posted. greatly appreciate the info!
Old 06-01-2013, 10:34 AM
Color: Gray
So I apologize for taking so long to reply but I cleared code and have not had any more issues...maybe it was a just a glitch or it read warm and now is back to normal?
Old 06-01-2013, 12:57 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
possibly. glad it worked out for ya tho
Old 06-01-2013, 02:33 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
I was under the impression that the dealership would need to reflash because of the newer design on the egrs?
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 06-03-2013, 08:25 AM
Rep:1900
oooooooo i dunno about that
i just reset everything by disconnecting the neg battery terminal.
everything seems fine
