Old 04-24-2013, 08:42 PM
Jettle Jettle is offline
Vehicle: 2013 Ram 2500 Laramie
Jettle is on a distinguished road
Default Removing Fuel Door
Does anyone know how to remove the fuel door on a 2013 2500 6.7l? There are two torqx srews that are easy to get to but there are two others inside the filler area that I cant seem to figure out how to remove.
Thanks!
Old 04-24-2013, 10:28 PM
Here are a couple pictures. I've circled the screws that I am having trouble removing.
Old 04-24-2013, 11:42 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Might have some luck posting over on diesel side...I saw a flexible shaft screw driver in Sears the other day that might work. It's a normal screw driver, but the shaft is flexible for hard to reach places. Just an idea?
Old 04-24-2013, 11:59 PM
Hi HorseMan,
Thanks for the response. The problem is that I can only see the back of the screws. I attached a couple pictures above but they may be hard to make out. I peaked up under the truck and can't get to them for there either.
Old 04-25-2013, 12:04 AM
HorseMan's Avatar
Rep:139
Originally Posted by Jettle View Post
Hi HorseMan,
Are you sure those have to come out to remove door? You might pull up the part on the Mopar parts site and see if you can tell how it's installed...sometimes there is a parts sketch or diagram? Maybe try parts counter at dealer? I'm just tossing out ideas...
Old 04-25-2013, 12:07 AM
HorseMan's Avatar
Rep:139
A better idea might be to try an auto body shop. If you're just replacing the fuel door, I know those nice chrome ones come with instructions...sort of reverse engineering, if you will. Grubrunner on here has a nice fuel door on his 1500... Might PM him. May not be same door on 2500?
Old 04-25-2013, 12:09 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I haven't pulled a dodge fuel door yet. I could use a few wider pics. If you pull the screws to drop the filler neck and get the plate out of the way can you get to them that way. If you take a few pics further out where I can see the whole thing I maybe able to give you more input.
Old 04-25-2013, 01:08 AM
Thanks for the responces guys. I bought the moper chrome fuel door and it arrived today. I've attached a picture and circled the holes that the problem screws are coming through. They included directions, but they were not updated to show pictures of the new bracket. The pictures in the directions show a flat bracket.
Old 04-25-2013, 01:10 AM
Also, I forgot to add. The truck just turned over 100 miles, so I havent just started just removing stuff until I get to them like I usually would. :-)
Old 04-25-2013, 01:21 AM
RyanJM's Avatar
Rep:67
Well I checked my 1500 and they don't use those holes they are just empty. After looking at the general location the only way I can see to access them is to pull out the couple screws holding the black plastic that keeps the filler neck in place dropping it out of the way, should give you some limited acess to the screws. It will be tight but you should be able to remove them, swap the cover, put them in the screw the filler neck back in place. Just my .02 from what I can see. If I had a 2500 I could have been a little more precise.
