Old 03-06-2014, 08:17 PM
cool81830's Avatar
cool81830 cool81830 is offline
Vehicle: 12 dodge ram 1500 longhorn
Trim Level: Longhorn Laramie
cool81830 is on a distinguished road
Default winch bumper?
Best looking winch bumper??? also interested in a rear bumper! put some pics up or websites please!! thanks
2012 dodge ram-- no mods yet but I'm working on it!
Old 03-07-2014, 08:35 AM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
The best looking is a matter of personal taste. I looked at pictures by searching google to decide what I want.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 03-07-2014, 09:10 AM
cool81830's Avatar
well the only one i found is iron cross and i can't stand the iron cross stuff
Old 03-07-2014, 08:16 PM
Rep:23
You don't have many options with a 1500. Iron Cross is what I settled for. I don't like the way the cut their name into the bumpers. Otherwise they are OK. What I did notice quickly on the truck is the front mounts for the bumper are not meant to hold anything more than the stock bumper. There is no way I would ever try to winch anything with it as is.
Old 03-09-2014, 10:38 AM
cool81830's Avatar
why do you say that? whats wrong with the stock mounts? I'm looking at boondocks bumper
Old 03-09-2014, 07:19 PM
Rep:23
The mount for the front bumper is a 14 or 16 gauge plate welded to the end of the frame and no other support except the tow hooks if you have them and the rear mount for them use rubber bushings in the mounts. The whole thing appears to be designed to easily collapse in the event of a front end collision. The tow hooks are even slotted at their rear mounts so the they can slide back if impacted. After I initially mounted the bumper it wiggled around like it was mounted on rubber bushings. If shook so much the fog lights were jumping all over the road.
Old 03-09-2014, 09:30 PM
cool81830's Avatar
guess ill be welding my bumper on there then!!
Old 03-10-2014, 10:19 AM
Rep:23
Don't weld the bumper on, you will regret that. You do need to reenforce the frame side of the factory bumper mount though.
Old 03-10-2014, 02:13 PM
cool81830's Avatar
So... I look at it. I can prolly weld thicker plates onto the mounts? You have a pic of the frame?
Old 03-10-2014, 02:47 PM
Rep:23
I don't have any pictures. I think you would have to cut off the plate to make a big difference. I didn't want to cut up the factory mounts so I added a brace that is welded about 10" back on the vertical piece that the tow hook is mounted to. I is attached to two of the bolts that hold the bumper to the end of the frame.
The bumper comes with two large brackets that mount to the end of the frame and then the bumper bolts to it. The mounting holes are rather large and slotted. I did not like that either so once I had everything lined up where I wanted it, I removed the bumper from the end of the frame and welded the brackets to the bumper.
If you can weld or have access to someone that can, it can be made a lot better than if you don't.
