Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 04-25-2013, 09:54 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
correct the iat sensor is between the air filter and the throttle body.
Sean
Old 04-28-2013, 05:34 PM
joe102951's Avatar
joe102951 joe102951 is offline
Vehicle: 2003 dodge ram 1500
Trim Level: slt 2wd
joe102951 is on a distinguished road
i cleaned the throttle body and that helped the idling issues .. but i still have the pcode 0113 comming up. i bought a new sensor and that didnt help . ive never touched the wiring what else can i do to fix it ??
Old 04-28-2013, 09:49 PM
snrusnak's Avatar
Rep:1385
Check the harness and connector as I mentioned before. Look for worn down wires, shorting out, loose wires at the connector, etc. Other than that I'm not sure.
Sean
Old 04-29-2013, 02:29 AM
joe102951's Avatar
Trim Level: slt 2wd
Thanks i will try that ..would pvc sensor make it not start when its cold?
Old 04-29-2013, 01:16 PM
snrusnak's Avatar
Rep:1385
I'm not sure what a pvc sensor is....
There is a pcv valve. It wouldn't effect this though.
Sean
Old 04-29-2013, 04:31 PM
joe102951's Avatar
Trim Level: slt 2wd
lol thats what i meant pcv lol
Old 04-29-2013, 04:59 PM
snrusnak's Avatar
Rep:1385
It's not a sensor, just a one way check valve that allows pressure buildup in the engine crankcase to vent out. It vents into the intake and is burned in the combustion process(emissions).
A clogged pcv valve can cause a few issues but the truck should start and run, this won't effect that.
Sean
