smoking and stalling at times - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-25-2013, 07:03 AM
dirty97ram dirty97ram is offline
Vehicle: 97 ram 1500 ext cab short bed
Color: bedliner
dirty97ram is on a distinguished road
Angry smoking and stalling at times
I got a 97 1500 5.9 it was burning a ton of oil so I pulled the heads and of course they were junk so I got a set of reman heads got them on new plenum gasket and all still smoking a bit when in higher rpms and when I downshift. then when it sits and I start it it will pour smoke.
the other problem im having that idk about is it randomly stalls with no warning and wont start back up unless I let it sit for 5-10 mins then runs fine like nothing happened
any help with either problem would be great
Old 04-25-2013, 10:12 AM
whilightning's Avatar
whilightning whilightning is offline
Vehicle: 2012 Dodge Ram express
Trim Level: Express quad cab
Color: Bright white clear coat
whilightning is on a distinguished road
I've seen this exact problem before, as it seems to be common with 2nd gen 5.9's. I hope this can help:
-seafoam your brake booster&gas
-clean your air filter
-clean your PCV valve
-*check your battery connection* dodges are touchy with the battery
If that doesnt fix it quick, i would look at your idle air controller valve or O2 sensor . My friend had to retune his TPS and the IAC. 02 and perge valve could be replaced if all else fails.
