Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-25-2013, 11:28 AM
Sailor1 Sailor1 is offline
Trim Level: Big Horn Edition
Sailor1 is on a distinguished road
Default Air conditioning and questions?
I have a 2010 Dodge Ram 1500 5.7L Hemi air conditioning was weak after this winter. Mechanic said it was 1/2 lb low added dye but could find no leak and said to come back in two weeks and he would look again. Has anybody else experienced this problem? Another quick question the rev limiter? keeps the truck from exceeding 105 mph how and what needs to be done to fix that issue. Do any of the power chips actually help performance and gas mileage? Sorry third question. Thanks for any help. Love my Red Truck.
Old 04-25-2013, 11:56 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
I haven't had any problems with my AC. I'd say do what your mechanic says, fill it up and then check it again in a couple weeks to make sure it isn't leaking. If it's low again they start digging into the system looking for the leak.
The rev limiter doesn't stop the truck from exceeding 106 MPH.... the speed limiter does. If by power chips you mean tuners, then yes. They are by far the best easy mod to increase power, torque, and fuel economy. They also have the option to up the speed limiter if you feel the need to do so. Along with many other options. Check out Bully Dogs, and Diablosports websites. You'll find some good information in the tuners.
Old 04-29-2013, 05:02 PM
Default Thanks
Thanks for your response and sugestions.
Old 05-01-2013, 07:21 AM
Hacksaw392's Avatar
Hacksaw392 Hacksaw392 is offline
Vehicle: 2011 Dodge Ram
Color: Black Pearl / silver
Rep:17
Hacksaw392 is on a distinguished road
Keep in mind that your tires are speed rated and may not be suitable (dangerous) for speeds over 105.
Old 05-01-2013, 08:11 AM
Grubrunner's Avatar
Rep:3883
....which is too often overlooked.
Well said.
Grub out!
