Old 04-25-2013, 11:19 PM
ghsaj ghsaj is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Color: Maximum Steel
Rep:20
ghsaj is on a distinguished road
Default HIDs?
Hey all was wondering if anyone has put HIDs in there 2013 ram sport with projectors? I'm having a little trouble finding a conversion kit online
Old 04-25-2013, 11:22 PM
slowx2 slowx2 is offline
Vehicle: 2015 ram 1500 cc sport
Trim Level: spot/wair
Color: Granite crystal metallic
slowx2 is on a distinguished road
I am also looking for some too.
Old 04-25-2013, 11:26 PM
Rep:20
Default reply
Do you know the bulb size for the projectors? I can't find anything online about it either
Old 04-25-2013, 11:53 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Here you go
http://shop.*************/ProductDet...%2EPROJ%2EHIDs
Old 04-25-2013, 11:59 PM
Rep:20
site didn't work
Old 04-26-2013, 12:13 AM
Rep:2026
Sorry, for some reason it won't post the link properly. Google retro shop, go to search by vehicle then 09+ Ram. Then find the one for '13 Bihalogen projectors.
Old 04-26-2013, 12:25 AM
Rep:20
Awesome, I found it. So the truck has a high and a low beam separate? Meaning I need to buy both the high and low kit?
Old 04-26-2013, 12:30 AM
Rep:2026
I'm not entirely sure how the '13 headlights work. I know the '12's have high beams which are also the DRL's just at half power. And then the low beams are the headlights that come on at night. The problem with running HID's in the high beams on those is that the DRL's no longer work. I'm assuming that since the '13's use the LED strip as the DRL's then you could do both the low beams and the high beams with no problems if that's what you want to do. If you don't use the high beams often you could just do the low beams (projectors).
Keep in mind you will also need the Ram wiring harness in order to avoid flickering problems.
Old 04-26-2013, 05:50 AM
Monster5601 Monster5601 is offline
Vehicle: 2013 RAM 1500 Laramie
Color: Cherry Red
Rep:465
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
http://www.ramforumz.com/showthread.php?t=138373
Old 04-26-2013, 11:09 AM
s1000rrhp s1000rrhp is offline
Rep:13
s1000rrhp is on a distinguished road
Call core customs... I use the canbus system from them have no issues... Ask for Alex say Doyle sent u. Will give u a good deal. They are plug and play and do not show up error codes. I have them in my low.. High and fogs. 587.893. 2673 or 403.668.6688
