do you need a pro with a scan tool to flush/change calipers? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 04-26-2013, 08:27 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Default do you need a pro with a scan tool to flush/change calipers?
so my right front caliper is sticking. need to replace it tomorrow. u have to bleed the brakes right? and don't u need a scan tool to make that happen? or is that only for some trucks?
help me pleaseeee
Old 04-26-2013, 08:45 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I'm interested in the answer to this. I've never used a scan tool to do so with vehicles with ABS but have always had difficulty getting it bled. I did always eventually succeed, sometimes it took coming back on a future day...
Sean
Old 04-26-2013, 09:26 PM
Rep:2929
there are youtube videos that show how to do brake jobs with ABS systems
one that i watched one showing a guy using vice grips with rubber hose over the pointed grips to pinch the fluid line off, close to the caliper
don't let the caliper hang freely on the hose, like this guy did
try to keep weight off of the hose
2005 Ram
2007 Ram
http://www.youtube.com/watch?NR=1&v=...E&feature=fvwp
just cut off the circular clips that hold the rotor stable, they only have them on there so that they don't fall off as the Ram travels on the factory assembly line to where the wheels are installed
Old 04-27-2013, 12:19 AM
Rep:1900
stupid question. how do I find out if I have ABS? chances are I do? look at my build sheet? I'm a little intoxicated and fear navigating my old posts for my build sheet thread
Old 04-27-2013, 12:30 AM
Rep:1900
build sheet says "BRRS 4 Wheel Disc Rr Anti-Lock Brakes". so just rear? it's my front caliper that's stuck
Old 04-27-2013, 05:08 PM
Rep:1900
never mind. caliper just needed a good cleaning. all is well. thanks for the help tho
Old 05-17-2013, 12:18 PM
Rep:1900
Ended up needed to replace the calipers. Just bleed like normal. The caliper decided to freeze up good right in front of a rinky dinky repair shop in the middle of no where. I lucked out.
$200 later :/
Old 05-18-2013, 11:21 PM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default You have ABS, I guarantee it
Look right under and NEAR the brake fluid master cylinder. If you see a square box with metal hoses, that's the ABS pump and you have 4 wheel ABS
If you completely change your brake fluid due to overhaul or tired fluid, the scan tool will make the ABS unit "cycle", gurgle, bubble and burp out the old brake fluid inside the ABS valves.
If you don't use the scan tool, then you'll (most likely) have a slightly to significantly "soft" spongy brake pedal after a flush.
