Is the Y pipe worth it? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-26-2013, 09:57 PM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
Default Is the Y pipe worth it?
Hello Everyone,
Thinking about installing the Magnaflow Y pipe and eliminating the resonators. I already have a magnaflow 14' muffler.....is it worth the time and money? Any advice appreciated. Happy Hemi day!
Scott
Old 04-26-2013, 10:20 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
I think, think mind you, that the factory y-pipe is designed the way it is to increase off-line torque and matched to the RPM that the engine runs 99% of the time. If I was going for better flow I would use the Flowmaster Y-Collector #Y214300. It has much better transition from 2 into 1 exhaust flow for better midrange and wide open throttle horse power. Mine, I'm leaving it stock, I like torque.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 04-26-2013, 11:05 PM
Rep:3337
While oldhp's thought have merit, if you want to start flowing more air then the y-pipe is a must. The very design of the factory y-pipe makes me cringe when I think about the compression that the heated air stream has to undergo before it vents into a much larger reservoir, killing flow velocity and increasing backpressure.
Old 04-27-2013, 05:41 PM
oldhp's Avatar
Color: WHITE
Rep:902
I agree for better upper RPM flow you need bigger I.D. pipe. But that high compressed air velocity going into a large reservoir (3" O.D. pipe) is almost exactly like a torque pipe on motorcycle engine exhaust. They did it for reason I believe. If it caused that much of a restriction, wouldn't you think it would restrict MPG, let alone HP & torque?
I don't know tomato/tomatoe, only the exhaust/engine designers know for sure.
How would you know?
Old 04-27-2013, 08:11 PM
Grubrunner's Avatar
Rep:3883
Yes, I believe it's a wise investment given is relative cheap price and install.
Equally important, and worth it, is the crimped LHS bank OEM pipe that runs under the trasmission.
Grub out!
Old 04-27-2013, 09:08 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
For the best results increasing AirFlow into the engine is a must for this you are going to want a larger throttle body, and preferably and Vararam or S&B, (I prefer Vararam as it shows better numbers, and IMO looks 100 times but), when this is done changing the mid pipe between the cats and the y pipe is preferred, along with the crushed y pipe, and you already have a muffler ready to go so thats good , and of coarse a tuner with a custom tune, that is about the most you are going to get done as far as basic bolt on goes and you will not be disappointed that is for sure.
If you need pricing on anything just let me know I would be more than happy to get you the best deals around, weather it is 1 part at a time or multiple
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 04-27-2013, 09:25 PM
Color: Mineral Gray
Rep:277
Thanks to everyone for your comments with this. When Im ready to spend $$ i'll be in touch with you Jeremiah
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Sounds good I will be here
Thanks
Jeremiah
Old 04-27-2013, 09:43 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Very good comparison sir! I also think the resrictive OE "Y" after the CAT's were made to function with the MDS. A little Backpressure is good from low to midrange but wide open throttle, no backpressure obviously is best.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 04-27-2013, 09:57 PM
oldhp's Avatar
Color: WHITE
Rep:902
I never thought of it that way with the MDS. Your right it would make even more sense the way it is designed.
Is anybody getting more MPG with the y-pipe modification and "not" using MDS?
How would you know?
