Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-27-2013, 08:02 PM
msorbara10's Avatar
msorbara10 msorbara10 is offline
Vehicle: 2004 Ram 2500 Hemi QC
Rep:41
msorbara10 is on a distinguished road
Default Just used seafoam for the first time
Well I decided to see what all the hype was about this product. I can tell everyone has had a good experience with this so I figured my engine could use a little cleaning.
I did this along with my CAI today and WOW what a difference.
I just put half the can through the line under the booster and then the rest in the tank. Let it sit for an hour, started it up let it idle, and drove it hard. The smoke didnt last too long and it wasnt as crazy as i had seen in videos on youtube but there was a good amount. But I will tell you what my throttle responce was so much better and acceleration was incredable. best it has been since having the truck for 4 months. I was actually going to reset the pcm today but I couldnt get the negative battery cable off the damm battery. But after driving it didnt seem like i needed it. I was shifting a lot better on the highway and I didnt have to put my foot down all the way and wait for the engine to finally get going..
I didnt put in the in crank because I just changed the oil last month with RP. I was actually wondering if it would be ok to use again at say the end of august when I change the oil again to use seafoam again? Let me know what you guys think of that idea. I will probly have used 6-7000 miles of RP. I know it lasts a long time but the oil that was in it before was really dirty from when I bought the truck so I wanted to run that less then what I could then change it and be even more sure I got less crap in there
But anyway, great product. Next time I use it I will try to make a video of it do 3rd gen guys who have trouble will be able to figure it out quicker
Old 04-28-2013, 08:24 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
It has better throttle response BC of cleaner pistons/intake valves. Good stuff.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 04-29-2013, 11:58 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
You just bought one can of it? I've thought about doing this but with my new exhaust setup I think I might wait a little while
Supercharged, cammed, other things too!
Old 05-02-2013, 11:35 AM
msorbara10's Avatar
Rep:41
Yes just 1 can. I used almost half in the brake booster line and the rest in the tank. Twards the end of the summer I will put some in the crank when I know I am going to so an oil change. What new set up do you have? I dont see how it could affect it in anyway
Old 05-02-2013, 07:56 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
An entire new custom exhaust setup and custom tune. I guess I just dont want to be doing anything till I break the exhaust in a little...
Old 05-03-2013, 09:36 PM
msorbara10's Avatar
Rep:41
Makes sence. Let me know when you do it I can help out if you need it
Old 05-06-2013, 12:52 PM
05MinGryHemi 05MinGryHemi is offline
Vehicle: 2005 Dodge ram1500
05MinGryHemi is on a distinguished road
Did you do a spark plug change after the seafoam? I read that it fouls out your plugs.
Old 05-07-2013, 01:51 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Sorry, you read some bad info, no need to change the plugs; in fact, they should be cleaner!
Old 05-07-2013, 03:21 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
OP, which CAI did you go with?
Old 05-09-2013, 10:08 PM
titanman2789 titanman2789 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:40
titanman2789 is on a distinguished road
Nice report on the sea foam. I used it on my first car - a 2000 Camry - when it had 180k miles or so. TONS of smoke out of that little 4 cyl motor. Actually, the reason I did it was because my CEL came on for the EGR valve on that car. Sea foam cleaned it out and CEL went off after another 3-5 cycles. It stayed off for about a year until the EGR valve completely went. But after my experience with it, I'm a believer in the stuff
