Will Not Move - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-28-2013, 05:42 PM
88D250's Avatar
88D250 88D250 is offline
Vehicle: 1988 Dodge Ram
Trim Level: D250
Color: Grey
88D250 is on a distinguished road
Default Will Not Move
88 D250, 318. Ive just got it running, however, I tried moving it today and it was a no go. I put it in gear and it engages, give it gas and it tries (faintly) to move, but just stalls before moving.
Old 04-28-2013, 05:50 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
have you checked the transmission fluid level with the truck in neutral?
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 04-29-2013, 11:53 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I agree.
If the transmission level is sufficient and you are feeling torque, then I would check the calipers and rear shoes and make sure each wheel is able to turn and not restricted by rust/corrosion.
Old 04-29-2013, 06:30 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
By "stall" are you referring to the movement of the truck or the engine?
Old 05-06-2013, 03:02 PM
1985dodgeramw100's Avatar
1985dodgeramw100 1985dodgeramw100 is offline
Vehicle: 1985 Dodge Power Ram
Trim Level: W100 Prospector
Color: red
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
1985dodgeramw100 is on a distinguished road
im with the other guys on the transmission fluid thing. however though it COULD not saying it is be some sort of brake issue
guts glory ram
Old 05-07-2013, 04:56 PM
88D250's Avatar
Trim Level: D250
Color: Grey
Sorry, my internet has been down for days. I checked the fluid, it was low so I filled it. It now moves, but very sluggish. If too much exertion is given (which is still VERY little) it will stall, generally with backfire out of the throttle body. I'm wondering, could this be at all due to a misaligned distributor? I pulled it out to change the ignition pickup, I marked it to make reinstallment easier, but I may have it out of alignment? Or is this still more likely a transmission issue?
Old 05-07-2013, 09:45 PM
timing could be off.
did you check the transmission fluid level with the truck running in neutral? could need a bit more fluid than you think.
Old 05-07-2013, 11:09 PM
88D250's Avatar
Trim Level: D250
Color: Grey
Yeah, I had it in neutral. Ill try playing with the timing as well. My diff is looking leaky too, I don't think its the issue, but it could be worth a look.
1988, d250, help!
