Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-28-2013, 10:50 PM
Gen1Ram Gen1Ram is offline
Vehicle: 1994 Dodge Ram 2500HD pickup
Color: Blue
Rep:17
Gen1Ram is on a distinguished road
Default AC Compressor
Not sure if its the compressor or clutch that is failing. But I have had my AC compressor replaced numerous times. First a rebuilt, failed within warranty period and replaced with another, failed as well. Went with a new one, failed as well, replaced under warranty and this time failed just beyond warranty. Is there something else that could cause my compressor and or clutch to be constantly failing?
Old 06-22-2013, 10:17 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Not sure why you are replacing the compressor constantly. They don't go bad just like that. In fact, most A/C problems is the clutch and not the compressor. Did you properly put the right amount of refrigerant?
Old 07-28-2013, 03:41 AM
tox's Avatar
tox tox is offline
Vehicle: 2000 Dodge Ram Sport
tox is on a distinguished road
I was just reading into this. It could be the drier. It helps to filter contaminants out of the system. I would replace that!
Here's more info: http://www.ebay.com/gds/WHAT-DOES-A-...0956464/g.html
2000 Dodge Ram 1500 Sport 360 quad cab loaded. Kegger mod: http://goo.gl/hXl48Z
Old 07-30-2013, 05:34 AM
GrimReaper GrimReaper is offline
Vehicle: 1997 dodge 3500
GrimReaper is on a distinguished road
My A/C compressor clutch is not getting voltage. 1997 3500. The A/C Compressor Clutch Replay in the Integrated Power Module is recieving voltage from the Powertrain control module and actuating, but there is no voltage present to send to the compressor clutch.
Chilton's does not contain a good schematic of the A/C wiring. There must be a fuse but it's not in the IPM or Junction block. Maybe it's time to get a better manual with A/C schematics. Thanks in advance, Grim.
Old 07-30-2013, 10:08 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check for current at the (inline) high pressure switch.
If there isn't sufficient refrigerant in the system the switch won't tell the compressor to kick on.
Old 07-31-2013, 08:02 AM
Went to NAPA this morning a the parts girl printed a wiring diagram for me. A 20 amp fuse is shown, identified as "B" in the IPM. Checked every 20 amp fuse and the last one was blown. The fuse identified as "horn" on the lid of the IPM. With a meter determined this "horn" fuse also feeds the compressor clutch.
Now to find out what is blowing this fuse. A/C compressor replacement was probably not needed. Thanks for the support.
Grim
