2006 Dodge 4 door third brake light leak? Couple questions.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 04-28-2013, 11:27 PM
sprint54fan sprint54fan is offline
Vehicle: 2006 Dodge Ram
Color: red
sprint54fan is on a distinguished road
Default 2006 Dodge 4 door third brake light leak? Couple questions..
Have a 2006 Dodge 4 Door Big Horn Edition.. bought it a few months ago and after it rained one night hard I found the 2 back storage containers under back seats flooded.. well it finally got warm out again so I used a hose and found the back slider window was POURING in water..so I had the slider back glass taken out and put in just a straight window back glass..well that fixed the BIG leak issue..
Well today it rained again and now I see my third brake light is letting water in on the passenger side only..driver side is dry as a bone.. the water will run down above the headliner to the side post and run behind the plastic piece on passenger side and go to the floor..its not SUPER bad but I want it fixed!
I read on here about replacing the gasket or also using silicon caulk and caulk around it.. I plan to just caulk around it ..
So my question is what caulk should I use..anyone have a NAME for it?
Also what are your guys opinions on using caulk to fix it..? or should I buy a new gasket from a dealer? Thanks!
Old 05-06-2013, 02:14 PM
Chris65 Chris65 is offline
Vehicle: 2007 Dodge Ram
Color: silver
Rep:45
Chris65 is on a distinguished road
The gasket has a adhesive strip on it.
Try with double sided tape -very thin snd transparent-and put it on to both sides of the gasket. Clean the contact surface on light and body good and install it. Should fix ur problem.
If not, new light/gasket.
Don't use that caulking or silicone crap. When u change the bulb u will have the sane priblem and it's just messie.
Old 05-08-2013, 12:41 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
i had the same issue with my 07 power wagon. i used two of the factory gaskets and it fixed the problem. just food for thought.
