Old 04-29-2013, 09:21 AM
4Play1 4Play1 is offline
Vehicle: 2011 CC Sport
4Play1 is on a distinguished road
Default 2/4" Drop and Airlift
Question for those with a 2/4" drop either Belltech or McGaughys.
What Airlift system are you using (P/N)?
60818 for 2009-2013 Normal ride height
or
60824 for 2011-2013 All wheel drive Durango
I see where people with drops are using both. Will the full size kit be to big for the lower coils?
About to load the family and suitcases and head to Florida after the 2/4 Belltech and don't want to fell the bump stops all the way.
Thanks,
STP
Old 04-29-2013, 01:19 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
If you do the 2/4 drop you'll want the Durango bags. The ones meant for the stock height Ram will be too long and you won't actually be dropping the back very far as the bag will be supporting more weight of the truck. If you have any doubts it doesn't hurt to contact the guys at Airlift and tell them exactly what your set up is. They will make sure you get the right product.
Old 04-29-2013, 01:42 PM
Thanks for the info. That was the same I was reading but just wanted to make sure.
