Old 04-28-2013, 04:11 PM
rpm27 rpm27 is offline
Vehicle: 2011 Dodge Ram 1500
Color: Green
rpm27 is on a distinguished road
Default Uconnect Not Available
Just installed the power lock accessory for the tailgate. While doing this I did disconnect the battery as I had to get to the wires under the fuse box. Now my radio does not connect to uconnect. I press the phone button and I get the message that Uconnect Not Available. It looks like I have the 430/RBZ radio. Any suggestions on a possible reboot to the radio?
Old 04-29-2013, 08:34 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
1) Does anything else not work?
2) I know you disconnected the battery for the install, you may want to try it again for about 10 minutes or so.
3) When you ran the wires under the fuse box, did you by chance knock any of the connectors lose on the fusebox?
4) The Uconnect system is separate of the radio on the RBZ and is located to the far right of the dash structure. It can be seen if you drop the glovebox down to the floor and look inside the GB hole in the dash to the far right. Did you have to run any wires in that area? If so, check to make sure that you didn't disconnect anything there.
