Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 04-29-2013, 11:12 AM
Hank426 Hank426 is offline
Vehicle: 2005 Dodge Ram
Color: Atlantic Blue
Hank426 is on a distinguished road
Default Should I do a transmission fluid/filter change?
Ok so I bought the truck with 100k miles on it and it now has almost 120K. My question is, is it still safe to change the two filters in the transmission and the 6-7 quarts of fluid? It's a 545 btw.
also I've heard that I shouldn't change the round filter seal and just leave the old one in? and that I should only use the mopar filters, only problem is I already bought the WIX filter kit (58843). One more thing, if it is safe to change, should I use the supplied rubber pan gasket or use rtv?
Thanks
Old 04-29-2013, 01:09 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I would think that mileage is fine to go ahead and change.
I wouldn't replace that rubber seal for the "flat" filter. If not installed properly it will damage the transmission. It shouldn't need replaced anyway, it is submerged in fluid at all times, it's not like it's dry rotted, etc.
I use the rubber gaskets just for ease at next service. But the rubber will crack, etc. Mine is cracked to hell with just about 25k miles on it although it doesn't leak.
If you already bought the WIX then I'd use it.
Sean
Old 05-02-2013, 10:56 AM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
I just did this on my 02' a couple days ago it took about 1.5 hours from start to finish. I opted for the rtv (ultra grey) sealed up nice and i have been using the stuff for years with great results. Just let the rtv dry before you start the truck up
Old 05-03-2013, 10:35 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:491
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
We have seen problems with some of the WIX spin-on filters in the past, so be aware that if you use that filter you might have converter drainback issues. The likelihood is probably small, and a bad filter will not damage your trans, you just might have to replace it again if you have problems.
If you use the WIX filter, and afterwards you experience: (1) on cold starts, trans seems to "ooze" slowly into gear (first engagement only), or (2) after a cold start, truck tries to lunge and you have to mash the brake pedal to hold it, then you probably have a bad spin-on filter. So if that happens, just change it out again and use a Mopar filter.
Old 05-18-2013, 08:13 PM
Thank you very much for the advice guys... anyone know the Mopar part number for the spin on filter? Thanks again
Old 05-18-2013, 10:08 PM
Vehicle: N/A
Rep:491
The spin-on filter is 05179267AC.
Old 05-19-2013, 09:03 PM
kittpowell1's Avatar
kittpowell1 kittpowell1 is offline
Vehicle: 2004 ram 1500
Color: red
Rep:17
kittpowell1 is on a distinguished road
when is the recommended milage to flush and change all tranny fluids?
Old 05-19-2013, 09:05 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
owners manual will have that in it
2005 Dodge NSRT-4
Old 05-22-2013, 08:03 PM
Vehicle: 03 Ram
That is a trick question
It really depends how you utilize your truck. If tow, haul, or drive hard you will want to change that fluid much sooner. I know people that change trans fluid every 20k, others that stick with 45-60 and then some that have never changed it...
Personally 60k is a good number on a daily drive normal truck.
just my .02
Old 05-22-2013, 08:17 PM
msorbara10's Avatar
msorbara10 msorbara10 is offline
Vehicle: 2004 Ram 2500 Hemi QC
Rep:41
msorbara10 is on a distinguished road
I will be looking to do this sometime soon also. Is there a link where I can get the filters I need to do this change?
