Old 04-29-2013, 05:21 PM
Shooterjim's Avatar
Shooterjim Shooterjim is offline
Vehicle: 2013 Dodge Ram 1500 Express
Color: True Blue Pearl
Shooterjim is on a distinguished road
Default Skid plates
My new 4X4, CC Express didn't come with skid plates and I was wondering if anyone in the forum knows of a business that makes them aftermarket or would I be better off getting them from the dealer? I don't anticipate a lot of heavy duty off road operation but want to have the protection if I do. If getting them from the dealer, would they be a bolt in installation?
I'm a first time Ram buyer and have read about different generations of the truck. Could someone enlighten me as to what this means? Thanks and happy driving.................
Old 04-29-2013, 05:41 PM
turbohawk's Avatar
turbohawk turbohawk is offline
Vehicle: 2013 1500 4x4 5.7 6spd
Trim Level: Express QC 6'4" bed
Color: Polar White
Rep:44
turbohawk is on a distinguished road
Hey Shooterjim! You beat me to the same question...let me know if you find out anything great outside of answers here.
Old 04-29-2013, 05:45 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
google is your best friend for both of these questions really.
I think there is a Wikipedia that explains the ram generations.
2009-present: 4th gen
2002-2008: 3rd gen (although 2002-2005 and 2006-2008 have some significant differences)
1994-2001: 2nd gen
1961-1993 and earlier: 1st gen
Old 04-29-2013, 06:04 PM
Brandon .30-06 Brandon .30-06 is offline
Rep:29
Brandon .30-06 is on a distinguished road
Yes it should be a bolt on thing. I know with the sport it is, give me you vin and i will run it on dealerconnect to see if it can be ordered on your truck
Old 04-29-2013, 07:51 PM
Eric32688 Eric32688 is offline
Eric32688 is on a distinguished road
I installed the factory skid plates on my 13' express about a month ago, it was an easy install and I'm glad I put them on. At the very least they help protect the electronic power steering unit and the electronic transfer case shift solenoid from any kind of road debris. I have part numbers for the 2 skids plus the cross member if you like.
Also, the holes are already punched at the mounting areas, but they are not yet threaded. The factory used M8x1.25x30mm bolts, but in reality you can use whatever comparable size you want that you have a tap for.
Old 04-29-2013, 08:02 PM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Trim Level: Laramie Longhorn
Rep:61
UpToNoGood will become famous soon enough
How much did they cost?
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 04-30-2013, 12:04 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
They do work. Mine already have some battle scars and I wouldn't say I do any heady duty off roading.
Old 04-30-2013, 12:11 AM
turbohawk's Avatar
Color: Polar White
Rep:44
Definitely going to want skid plates. Are the factory units steel and pretty heavy duty? What do they run pricewise? I'm kinda confused about the "not threaded", does that mean we need to do some tapping to install them?
Old 04-30-2013, 01:50 AM
I was fairly impressed with the skids after I ordered them, they are a good thickness and provide good protection against bumps and scrapes. Here are the part numbers:
Skid plate (You'll need 2) = 68089777AB
Cross Member (1) = 52022046AG
I paid a total of about $100 after shipping. In reality I thought it was all pretty cheap, and I just went to my local Lowes for the right size grade 8 bolt.
In regards to turbohawk, yes you'll need to tap the holes. But on the good side you wont need to mark and drill; the hole is there but it is to small and is un-threaded. Hopefully that makes sense.
Also if any of you guys want any pictures, I'll be more than happy to go take of few when it's daylight.
Old 04-30-2013, 02:45 AM
Shooterjim's Avatar
Default Re: skid plates
Thanks for the reply and part #'s. I will go and check with the dealer on my next day off. Luckily, my son works at the dealership where I bought the truck so I get his discount. I'll try to post some pix after installing them if I can. At the very least, it will be good protection for the steering and transfer case electronics.
