Old 05-01-2013, 04:24 PM
turbohawk's Avatar
turbohawk turbohawk is offline
Vehicle: 2013 1500 4x4 5.7 6spd
Trim Level: Express QC 6'4" bed
Color: Polar White
Rep:44
turbohawk is on a distinguished road
Originally Posted by Eric32688 View Post
In regards to turbohawk, yes you'll need to tap the holes. But on the good side you wont need to mark and drill; the hole is there but it is to small and is un-threaded. Hopefully that makes sense.
Also if any of you guys want any pictures, I'll be more than happy to go take of few when it's daylight.
Thanks Eric! Where did you order from? And yes, if you can take some pics that would be great!
Old 05-02-2013, 07:32 AM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
I was fairly impressed with the skids after I ordered them, they are a good thickness and provide good protection against bumps and scrapes. Here are the part numbers:
Skid plate (You'll need 2) = 68089777AB
Cross Member (1) = 52022046AG
I paid a total of about $100 after shipping. In reality I thought it was all pretty cheap, and I just went to my local Lowes for the right size grade 8 bolt.
Hi, would you know the guage of the plate ?
Regards
Old 05-02-2013, 07:34 AM
arietem's Avatar
Rep:368
Originally Posted by Shooterjim View Post
Thanks for the reply and part #'s. I will go and check with the dealer on my next day off. Luckily, my son works at the dealership where I bought the truck so I get his discount. I'll try to post some pix after installing them if I can. At the very least, it will be good protection for the steering and transfer case electronics.
Hi, any luck with the photos ?
Regards
Old 05-02-2013, 07:37 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
how to post pictures:
http://www.ramforumz.com/showthread.php?t=139666
Old 05-02-2013, 09:06 AM
nikeman nikeman is offline
Rep:91
How hard are they to thread? I have seen taps before and only used one one time to fix a sparkplug hole in my very first car so I have never actually threaded a hole before. Do they come with instructions that tell you what size tap to use? I'm interested in this also! How much would they cost installed at the dealership?
Old 05-02-2013, 11:38 AM
Eric32688 Eric32688 is offline
Eric32688 is on a distinguished road
First off, sorry everyone I forget to check on the forum every day but I'll go out this morning and take some pics and get them up. In regards to taps, the skid plates can be tapped easily, just make sure to put fresh cutting oil on the tap for each hole so you don't dull the cutting threads. You could have the dealer do this for you, but I'm sure they'll charge you for an hour or two of labor and in reality you can do this job by yourself no problem.
On install there is only one part that gave me a little trouble. When installing your cross member, you will need to tap 4 holes that are going in to your frame. The holes are in a tight spot at a 90 degree angle, and needless to say your frame metal is quite strong and resistance to being tapped. For the 4 bolt holes I switched to a 1/4" tap that was much closer to their hole diameter, this made it a lot easier to get it tapped without much trouble.
Ok, before anyone laughs or makes fun of me, if you have a harbor freight by you; they actually have a good set of alloy steel metric/sae tap and dye set with all you'll need.
In regards to where I ordered from, I used moparonlineparts.com. They were friendly and helpful.
Old 05-02-2013, 12:45 PM
Not great, but here a few pictures. Also, I wasn't able to get dropbox to allow the pictures to show up on the forum directly. Dropbox creates a webpage link with the picture, not a link that is directly the picture; so I couldn't get the html code to recognize that. If someone has any other suggestions on how to code the link I will gladly change it.
https://www.dropbox.com/s/ta1jhao2lg...2008.22.42.jpg
https://www.dropbox.com/s/khwn00kj3x...2008.22.48.jpg
https://www.dropbox.com/s/1skv1bzv44...2008.23.05.jpg
https://www.dropbox.com/s/3n12ps1n4b...2008.23.32.jpg
Old 05-02-2013, 01:17 PM
Rep:91
I wonder if my dealer will transfer my skids from my '11 outdoorsman quad to my '13 sport when it arrives. I'm pretty sure my truck has them but not 100%. Will have to check before my new one comes in.
Old 05-02-2013, 01:55 PM
bigralphy bigralphy is offline
Rep:39
bigralphy is on a distinguished road
Your outdoorsman should have them.
Old 05-02-2013, 05:21 PM
Jake95's Avatar
Jake95 Jake95 is offline
Vehicle: 2013 ram sport 1500
Rep:29
Jake95 is on a distinguished road
I need to get that, if my truck ever arrives
