Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Product Reviews
Product Reviews Have you found a great product, or a really bad one and you just need to tell someone about it! Post up a review for the benefit of all!
Old 04-29-2013, 05:40 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Talking Brake flaring tool review
http://www.eastwood.com/professional...ring-tool.html I bought this tool a while ago and have used it on my 02' ram and my Golf. The tool is a bit pricier than some other clamp type tools, but after using both types, this is the way to go. I have used this on ferrous and non ferrous tubing. Brake lines and gas lines. With both tools, you use a tubing cutter, install your nut, ream the tubing. With the c-clamp type of tool, I always got so-so results. With this pro tool, everytime it is PERFECT. To use this tool, set the base in a vice and secure. Insert the handle into tool. Next, insert 1/2 of the die for your size of tubing, cover with second half of die. Close the clamp and tighten. Spin the turret to the part that kind of looks like a plain flat bolt and pull the handle. This makes sure your tubing is flush to the face of the die. Next, rotate the turret to Op 1 [operation] to your size of tubing; pull the handle. Next, rotate the turret to Op 2, your size of tubing and pull the handle. Your done with a perfect flare. This tool makes SAE and European DINN flares. Simple and perfect. Can't say more or how easy it is. Here is a utube vid on some used including the one above.
Old 05-02-2013, 02:26 PM
Big Boi's Avatar
Big Boi Big Boi is offline
Vehicle: 09 Hemi 1500
Trim Level: BigHorn
Big Boi is on a distinguished road
Nice review. I needed one of these while repairing my 20 gallon air compressor. Borrowed one very similar and it worked like a charm.
