Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
MOPAR DECALS
Old 04-29-2013, 09:51 PM
Big Dog 2008 Big Dog 2008 is offline
Vehicle: 08,3500 and 06,1500
Big Dog 2008 is on a distinguished road
Default 2000 3500 has scary rear brakes, will it stop or not?
I work for an excavation company that has a 2000 3500 with a full size utility tool box. This truck has been to the dealer 6 times and still has issues. The way I understand it, the rear brakes are to engage first. This truck does it backwards
and gets our pucker factor going. Could there be an issue with the hydroboost system or proportioning valve if it has one. All the brakes and components are brand new and the abs seems to be working as it should.
Old 05-01-2013, 11:09 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:762
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
that sounds backwards to me., but i am not a mechanic. my 04 3500 cummins went through front brakes before the rear.
Old 05-01-2013, 11:16 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Idk if it's different for big trucks but i think it's front brakes activate before/more than rear.
Old 05-01-2013, 11:17 AM
Rep:762
also, i doubt i would drive a vehicle if i wasn't sure if it was going to stop or not.
Old 05-01-2013, 05:02 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
I don't get it, as far as I know, the brakes are suppose to engage at the same time, but as a rule the front brakes do more work.
Old 05-02-2013, 12:23 AM
Rep:762
maybe ram tech will jump in and give you some expert advice.
Old 05-02-2013, 12:48 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
It makes sense to me that the back brakes would lock up first because of the heavy utiliy box. If the front brakes locked up first maybe they would slide because of the weight from the utiliy bed. If you had a heavy boat behind you and only had front brakes you'd be in big trouble. Back breaks with a heavy rearend would most likely be better. I don't know what do you guys think about that? Must be the reason for being bass ackwards.
Old 05-02-2013, 06:39 AM
Rep:1900
ya that's what I've heard too. It's a percentage...like front brakes do say 70% of the work and rear do 30% (just makin up numbers here)
but this makes sense too, that's why I wasn't sure for heavy duty trucks
Old 05-02-2013, 11:01 AM
dodge man's Avatar
Rep:235
The entire idea of ABS brakes is to get maximum braking from both the front and rear brakes when you put the brake pedal to the floor. I'm guessing the OP's problem is for more normal braking. It could be the normal brake bias isn't set up the way they want it. It could also be an issue with the hydroboost. It could also be a sticky caliper or a bad one, air in system, etc. I put rebuilt calipers on the back of my truck and one was defective. So far, my hydroboost system has been fine, but I've read that they can be a problem.
Old 05-02-2013, 12:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
The brakes are "activated" at the same time. The front brakes get the majority of the braking force. Most vehicles(trucks especially) will lock up the rear wheels first in a hard stop due to weight shifting off the rear onto the front(and trucks already are light in the rear). Most newer trucks have abs only in the rear. I'm not sure about what the 2000 would have as far as abs.
Sean
