Old 04-29-2013, 10:35 PM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Default Is this a Warranty Item
I carried a large amount of dirt and stone this past weekend working on the yard. At the end of the day I hosed out the bed. I have the factory spray in liner. As I was washing off the tailgate I got done and went to close it and the tailgate had a lot of water inside of it. Let it down and hosed it off some more and closed it same thing.
After looking it over there is a panel on the inside of the tailgate basically looks like an access panel and it appears there is a small gap I guess from the spray liner allowing leaks.
Also once I closed the tailgate you could see where the water was coming out just below the tailgate "cap".
My concern is the camera on the inside of the tailgate getting water on the connections.
Is this a fit and finish issue that warranty can address or just one of those little things you either live with or fix on your own?
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 04-29-2013, 11:00 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I would take it in. I would imagine it is but what's the worse they can say. No.
Old 04-30-2013, 04:53 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
I'm not sure how the factory does it but the access panel may be removed when they spray the bed? That way if there is an internal tailgate issue, they can still get in there. If they sprayed over it, you'd have to cut the bedliner to get inside. Anyway if they spray it removed, there may just be a little bedliner material holding the panel up away from the tailgate. The panel is held on by a few torx bolts. Depends on what you are comfortable with doing. If it looks as though the panel will lift out and the torx bolt heads are clean, I'd do it myself. If not or you are unsure, let the dealer handle it. I always lean to the side of the less trips to the dealer, the less chances they have of screwing something up though.
The connections in the gate are watertight, same as under the vehicle.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 04-30-2013, 07:08 PM
jeepguy's Avatar
jeepguy jeepguy is offline
Vehicle: 2013 Ram Sport
Color: Deep Cherry Red
Rep:29
jeepguy is on a distinguished road
The tailgate has huge holes at the bottom to allow water to drain out. Not really a warranty item.
