ZDOG
Old 05-04-2014, 10:29 PM
fat frank fat frank is offline
Vehicle: 2012 dodge ram 4 X 4
Trim Level: lonestar
Rep:14
fat frank is on a distinguished road
Default Tuftruck Coil Spring Install
Just bought a set of the 25% heavier payload coils for the rear of my 4X4. Anyone replaced their rear coils who could give me some advice. Appears that they can be removed when you lift the truck by the rear frame and the wheels clear the ground. Is there enough clearance at this point to wiggle them out and install the new ones. If I disconnect the lower shock bolt will this let the axel down lower? If so, do I have to support the axel? Any replies here would be appreciated. Thanks in advance.
2012 SLT 4x4; 5.7 Hemi: AirAid CAI; 2 1/2" Daystar leveling kit; Cabin AF installed; Black aluminum tool box; Front Receiver Hitch in near future.
Old 05-04-2014, 10:39 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
I did just as you said. Raise the truck by the frame, take off the rear wheels, I also unbolted the rear sway..not sure if that helped. Remove the stock coils and make sure to use the rubber boot on the stock ones. Move it over to the new coils and install.
Chrome... in moderation.
Old 05-05-2014, 08:42 AM
Rep:14
You raised the truck by the frame and didn't remove the lower shock end? Did you need a jack under the differential? Also how hard was I to persuade them to come out? Generally, every time I start something it turns into a nightmare. It seems pretty cut and dried. Just waning to make sure I have everything I need on hand when I start. Thanks for our input and for any additional info you might have.
Old 05-05-2014, 09:34 AM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:17
Hemi HFE is on a distinguished road
I just did this (well they were lowering springs ) on my '13 so it should be fresh, here goes, lol tougher w/o a lift:
1. 'chock' both sides of both front tires
2. raise truck by rear axle until wheels clear, put jackstands under both outboard sides of axle,
3. remove jack, put under frame point in center rear - receiver hitch ?, lift a bit.
4. remove rear wheels, lower shock mounts , brake line 'routing clip',
5. continue to lift frame, watch brake lines wires etc , you may need to remove lower panhard bar mount bolt &/or sway bar link bolts to get adequate travel to:
6. eventually all the load will come off springs,
then you can R&R, re-use the OE rubber cap and spring dampers,
and then reverse the process to put back together.
I recall needing a 21 mm wrench & socket, & the usual 18, 15, ..
the "gearwrench" style ratchet box-end are nice down here e.g. lower shock bolts
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 05-05-2014, 10:53 AM
Rep:14
Thanks for the reply. Getting harder by the minute for an old man. Thanks again for the info..
Old 05-09-2014, 11:47 PM
hemi deep hemi deep is offline
Vehicle: 2011 1500 Bighorn
Rep:65
hemi deep will become famous soon enough
I unbolted the sway bar links, and the lower shock bolts. Makes it easier for sure.
Old 05-14-2014, 05:19 AM
Rep:14
Getting new shocks at 4 Wheel parts Saturday. Gonna let them get dirty for me.
Old 05-14-2014, 08:03 AM
Rep:1385
It's much simpler than a lot of the above replies IMO...
I just chocked the front wheels then lifted the truck by the trailer hitch until the rear tires were off the ground about 1". Then pull the stock springs out and put the aftermarket springs in. May take a slight amount of force to compress them ever so slightly but I was able to do it laying on my back. Takes me about 15 minutes to swap from stock springs to aftermarket(lowering). Also once the truck is jacked up be safe and put jack stands under the frame.
Actually I have airlift air bags in the lowering springs now so it'd take longer. I used to swap to the stock springs if I needed to increase payload or towing capacity for a trip but now I leave the lowering springs in and pump up the psi in the bags.
Old 05-15-2014, 09:39 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
http://www.ramforumz.com/showthread.php?t=164282
As Sean said. It's easy
"I don't care to hear what your ideas are, mine are better"
Old 05-15-2014, 09:53 PM
rts551 rts551 is offline
Vehicle: 2013 RAM
Trim Level: SLT Big Horn
Color: copper
rts551 is on a distinguished road
I had to remove the lower shock bolts to get enough space to get the old spring out.
raised the truck until no tension on the shock. then raised the truck until the wheels started to come off the ground. I watched the brake lines but did not have to remove the clip. I got the progressive springs and they went in easier (1/2 shorter) than the originals.
