Old 04-30-2013, 09:14 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
my apologies. sorryyyy
Old 04-30-2013, 09:20 PM
Asur Asur is offline
Vehicle: .
Rep:4373
If it was doing it before and after the tune its worse, Its hard to say what it could be, I mean there are so many things that could be the issue, from a bad ground to the ECU itself, and no code????, hmmm, Once it stalls can you start it back up right away?
Old 04-30-2013, 10:35 PM
littlegirlbigtruck's Avatar
littlegirlbigtruck littlegirlbigtruck is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: SLT Sport
Rep:23
littlegirlbigtruck is on a distinguished road
Correct sir. Right away it starts up. If stops like a manual, like it is stalling. Only when I take my foot off of the gas.
I am just a little girl in a big ass truck!
Old 05-01-2013, 01:29 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
You may have messed up your truck but I don't think it's the tunner causing it (if you set it back to stock). If you put it back to the stock settings then everything goes back to exactly the way it was before you touched it. What you should do is get one of these guys (excluding me) on here to walk you through it via phone to resolve it...it takes 5 min to tune it. Disconneting your battery DOES NOT set it back to stock. I just installed a new battery and my tune stayed the same. I'm sure it's just a minor glitch. As a reminder, you have to make sure all power is off when you do this. Radio, fans, lights, door is shut, everything...k? I haven't messed with my tuner in a while so I'm a little rusty. I don't know if you did this, but before you tuned it you should have updated the tuner via computer or checked for updates. Also for future porposes always set the tuner back to stock before you update it or the update won't work. I'm sure your tuner came to you in stock setting or you couldn't use it because it would be vin locked. I wouldn't waist the money at a shop YET if I were you. Anyway, I'm sure someone on here would jump (respectfully) at the chance to help you via phone. If I see today that you get no help I will assist you via phone. But don't waste your money until you set it back to stock tune by way of tuner. It's very simple
Old 05-01-2013, 07:23 PM
Rep:23
Thank you so much for the offer, you're so sweet! I actually had the tune installed correctly (I did it myself and also once on the phone with superchips) My truck just didn't like it for some reason. I just got it back from the shop, $160 dollars later, they adjusted my idle up to 650 and cleaned out my IVC or whatever it is. It is running better now. No more random shut downs. Somehow they managed to knock my REM wire loose from my $3,000 sound system so I had a minor heart attack on that one, but I was able to track down the wire and reconnect it. Lucy is almost good as new! I really appreciate everyone's help. You guys are the best.
Old 05-01-2013, 07:47 PM
Vehicle: .
Rep:4373
Glad you got it all sorted out, reps for the sweet ride by the way .
Old 05-01-2013, 07:48 PM
Rep:1900
glad everything worked out
Old 05-01-2013, 08:23 PM
RadioFlyer's Avatar
Rep:146
That's great... so did you reload the tune since you got it back? Or was it still in when you dropped it off to get fixed?
Old 05-01-2013, 08:36 PM
Rep:23
Thanks boss, I really appreciate it!
Old 05-01-2013, 08:38 PM
Rep:23
Me too hun, thank you!
