mild lift,35 and bed load! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-30-2013, 10:19 PM
CaptainCurseD9H's Avatar
CaptainCurseD9H CaptainCurseD9H is offline
Vehicle: 2011 Dodge Ram Sport
Trim Level: Sport Crew Cab
Color: Charcoal
CaptainCurseD9H is on a distinguished road
Default mild lift,35 and bed load!
Hi guys , i have a 2011 1500 sport with a 2.5inch daystar lift all around and i want to get 35x12.5x17 tire on a 0 offset rim but im affraid about the amount of clearance on the rear wheel because im planning to load my Atv in the back and i dont want the tire to rub the fender when going into bumps and stuff like that...Does i need to go into a smaller size or that will be ok?The tire gonna be Toyo MT Thanks a lot!
Old 05-01-2013, 12:07 AM
jake09's Avatar
jake09 jake09 is offline
Rep:56
jake09 will become famous soon enough
Should be fine...Could get rear coil spacers or air lift bags for the springs even to help
2009 Ram 1500 4x4
6" superlift, 1.25" bl, 37 nitto mg's, & too much to list..
Old 05-01-2013, 12:37 AM
Color: Charcoal
The rear have a 2.5 spacer that was coming with the lift kit...As i seen on other leveled ram with 35inch tire theres not much room for travel.. , i was looking for the 295/70R17 tire size too of the toyo MT for a sure fit but i think they will be too much small..
Old 05-01-2013, 11:50 AM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
I went with 35x12.5x17 Toyo MTs on 0 offset XD Crank rims on my 2010 Sport. So far I have zero issues. I have a 2.5” front spacer and a 1.75” rear coil spacer made by Rough Country. The back end will sag a bit with a heavy load, you won’t have any issues with rubbing in the rear end when fully loaded.
However if you’re planning on over loading your bed to the point where your headlights are squirrel hunting in the tree tops I would definitely invest in some airbags such as the Airlift 1000. I would be more concerned about how your truck handles instead the amount of sag in the rear. It’s better to be safe than sorry. The Airlift 1000 will be my next MOD for that very reason and for the $150 bucks it will cost you why not?
Here is the link for the Airlift.
http://shop.airliftcompany.com/produ...g_Leveling_Kit
I attached some pictures so you can see what you’re getting into with the set up you’re planning on running. Keep in mind you will have some extra rear tire clearance compared to my set up since I only have a 1.75” rear spacer.
Enjoy!
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
Old 05-01-2013, 10:41 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Enjoy!
Very nice looking!
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
