Old 05-03-2013, 12:42 PM
satan47's Avatar
satan47 satan47 is offline
Vehicle: 2013 Dodge Ram
Color: Mineral Gray Metallic
satan47 is on a distinguished road
Originally Posted by jhinkle1989@discountautoperformance View Post
I agree 100$ pretty much, I think the S&B's look ok however like you said the gains are barely noticeable when compared to the Vararam, With the Vararam you will get the most power out of any CAI currently on the market
And on top of that we just kicked off a new promo where all forum member get a very nice discount, and a chance to get either their full purchase refunded to there payment method, or $400 in store credit! Check it out Vararam GIVE AWAY/Group Buy
Thanks
Jeremiah
Discount Auto Performance
thanks! i will send you a PM if i go with the vararam. so i have a feeling you will be hearing from me.
LineX,10tint,AriesW2Wsteps,Sonnaxbooster,20x9XDMon sters,295/65/20 TrailGrapplers, 4" CST lift, rear 1.5" spacers/5100's, 87mmTB,SB CAI,18" Maganflow/Y pipe,BT Catchcan, T1000, Factory 4.10s, transgo shift kit and JBA headers, Maghytec diff/tranny cover
Old 05-03-2013, 10:47 PM
Grubrunner's Avatar
Rep:3883
...... I think the S&B's look ok however like you said the gains are barely noticeable when compared to the Vararam, With the Vararam you will get the most power out of any CAI currently on the market
What evidence do you have to back this claim?
Grub out!
Old 05-03-2013, 11:31 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
+1 on that!! I can honestly say the K&N CAI kit for the 4th gen Rams is the cheapest looking one I've seen! S&B is probably the nicest looking one out there.
The Vararam is going to give you better HP and torque numbers than the S&B no question. Honestly the S&B probably won't give you any noticeable gains. They will be very minimal if anything.
Now for the tuner!! It is by far the BEST option to help get your power and fuel economy closer to stock. It will actually give you noticeable gains all around. That's something you should definitely be considering right away. With your throttle body and exhaust the whitelightning custom tune would be a great choice for you. Contact Jeremiah or Andrew and Discount Auto Performance to get the best pricing. They'll hook you up.
Jeremiah: jhinkle1989@discountautoperformance
Andrew: fastNugly@discountautoperformance
I'd also recommend 4.56 gears as well. If you're going to go through the hassle of changing gears you might as well do it right and go big!
I know what the Manufacturers tell me, and what Dyno sheets I have seen. So far of the dyno's I have seen the Vararam out performed every other filter. We are currently in the process of doing our own in house Dyno testing on different CAI's waiting on a couple more to show up and then we will be off to the Dyno to get some unbiased results, we are hoping to have them completed by mid summer I am going to be testing 4 units. Vararam, s&b, k&n, and volant. The reason I am doing this is because not all manufactures will post their results so I figured why not go get them
Thanks
Jeremiah
sales@revelperformance.com
Old 05-03-2013, 11:39 PM
Grubrunner's Avatar
Rep:3883
I look forward to your test results.
Please be certain to post ALL methods of testing in detail.
Thx.
Grub out!
Old 05-03-2013, 11:48 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Thx.
will do, I am going to revert my truck back to a factory tune, factory throttle body, factory wheels/tires, and factory air intake for a base tune. and then change the intake do the runs, change it again do the runs, and so on untill I am out of intakes, and then add the 85mm throttle body, then a tune, and so on, and then up to the 87mm and repeat. It is going to take a couple of months to compile all of this and get it done as I have limited Dyno availability, and a good amount of time pulling out parts and adding parts. The only thing that wont be factory on the truck for the base pull is the muffler and tips.
I will document heat indexes, ambient temperature, humidity, etc etc.
Thanks
Jeremiah
Old 05-04-2013, 04:38 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Thanks
Jeremiah
Thanks
Jeremiah
That's awesome! Definitely looking forward to seeing those results. Great idea! Are you not going to test out the Airraid CAI?
Old 05-04-2013, 11:43 AM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
If I can squeeze it in I will, I do have one so it is a very good possibility it gets tested too , I need a factory air intake assembly who wants to donate one lol, I'll give I back after the base tunes are done
Thanks
Jeremiah
Old 05-09-2013, 02:42 AM
satan47's Avatar
Thanks
Jeremiah
i have my 2013 factory setup that i just took off. problem is i'm in san diego and not quite sure what shipping would be. maybe we could work something out.
Old 05-09-2013, 02:48 AM
satan47's Avatar
OK.....so after the S/B CAI and the moes 87 TB have been installed the truck is almost back to where it was with the stock tires and ride height. i couldnt be more pleased with the throttle response and the torque i have gotten back. hopefully it will get even a little better once i install the 18" magnaflow muffler and Y pipe.
Old 05-09-2013, 04:26 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Nice combo there, any pics???????????
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
