Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Old 07-20-2013, 12:50 PM
hagswithnags hagswithnags is offline
Vehicle: 2003 Dodge Ram 3500
hagswithnags is on a distinguished road
Question "Over Horsed" My Truck
I just traded a 12,000 horse trailer for a 14,000 pound (GVW)horse trailer. My truck just turned 200K and I am wondering what I might need to do, additional to regular maintenance, to keep my truck running and healthy. I did notice that my truck has started running at 200 degrees rather than the usual (for the last 10 years) 185. Should I be concerned? Thank you. HwN
Old 07-20-2013, 08:01 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Injector service, check out the trans, the extra weight could be causing the trans to produce more heat, and in turn heating up the engine. Also, a radiator flush may be in order, even with regular coolant flushes, a radiator can still get gunked up...
Old 08-06-2013, 11:59 PM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
Transmission flush, cooling system flush and change your thermostat. All of that should help. Key there is cooling system and transmission flush and not just drain and refill.
Also make sure you are changing your spark plugs every 30,000 miles like your supposed to. That is something that is often overlooked and you start loosing HP if you let them go to long.
If i can kill it with an arrow, I'll eat it.
Old 08-07-2013, 12:03 AM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
The Cummins have spark plugs?!
New audio build in progress
