Rough country lift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-01-2013, 07:09 PM
Goose22 Goose22 is offline
Vehicle: 2007 big horn edition
Goose22 is on a distinguished road
Default Rough country lift
I just ordered my 6 inch kit for my 07 and was wondering if anybody was running the kicker bars and if they are worth it. Have not ordered them yet. Also is a35 a good size tire for this kit? I run 20x12 wheels with -13 offset
Old 05-01-2013, 07:14 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Kicker bars just mount from the rear front cross member back to another point on the frame for added strength. They're recommend for more offroad use. People that mainly drive them on the street put them on more for looks. It might be a good idea to have them as peace of mind.
35's look okay on a 6" lift IMO. But you can go to 37's. That's more typical.
Now the big one.... you have 12" wide wheels with only -13 offset? Are you running them now? That's only 5 7/8" backspacing. People running 12.5 wide tires on 9" wide rims are going with 5" or 4.5" backspacing. That is on 4th gens however but I don't really see how a 5 7/8" back spacing is going to work on a 3rd gen.....
Old 05-01-2013, 07:24 PM
The wheels when I ordered said they had a 4.5" back spacing and they rub a lot nor bc I only have it leveled. And I was Gunba run a 35x15.5r20
Old 05-01-2013, 07:26 PM
Well I gues it's a 20x9 inch wheel my bad I worded that wrong the first time. I have 20x9s with -13mm and I'm running 2 inch spacers sorry lol
Old 05-01-2013, 07:31 PM
Moderator
Rep:2140
Haha, okay! That makes more sense! Then you shouldn't have any problems.
Old 05-01-2013, 07:38 PM
Do the kicker bars show??? I guess I'm confused on the whole concept lol I understand what they do but will they look the torsion bars or what?
Old 05-01-2013, 07:42 PM
Moderator
Rep:2140
They will show underneath a little bit and yes, kind of do look like torsion bars. They will be in essentially the same place as the torsion bars, just further in to the middle of the truck. Check out Ram725's build thread. He has them installed with his 6" RCX lift.
Old 05-01-2013, 07:46 PM
Ok I will for sure check them out! Thanks for the help and I will post pics after I get her all build!
Old 05-01-2013, 07:48 PM
Moderator
Rep:2140
Sounds good Look forward to seeing them!
