Plenum Leaking? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-02-2013, 08:59 AM
rudkinp00's Avatar
rudkinp00 rudkinp00 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie Ext-Cab
Color: Forrest Green
Rep:55
rudkinp00 will become famous soon enough
Post Plenum Leaking?
after reading people who had this problem i am beginning to think i may have the same problem, before i put on the glasspack the motor had a slight tick and it has always been slow and feels bogged down, i heard to look down into the throttle body and see if there is oil present, i am assuming with engine off? also can this problem only show by a ticking and being sluggish, like will there be smoke from the exhaust or oil level dropping i want to get a second opinion before i remove the intake, it is kind of a pain in the ass
Old 05-02-2013, 03:59 PM
FilthyDog's Avatar
FilthyDog FilthyDog is offline
Vehicle: 1999 Dodge Ram 1500
FilthyDog is on a distinguished road
you are correct. With the engine off, remove the air filter and take a look down through the throttle body. If you see any pooled oil, you have a blown plenum gasket.
my symptoms were rough idle, low power, bad mileage(9mpg), oil consumption(1 quart per tank of gas). I did not have a noticeable amount of smoke out the tail pipe.
I took some pics of my plenum repair and posed them here:http://www.ramforumz.com/showthread.php?t=127559
Good Luck,
Filth
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
