Old 05-02-2013, 06:37 PM
quicksilve quicksilve is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Outdoorsman crew cab
Rep:17
quicksilve is on a distinguished road
Default Will they Fit
Hey guys I have a set of 20" KMC rock stars specs are:
20X8.5
Offset 10mm
Hub:78.1
Tires: 35 X 12.5 Toyo AT 2
I just made an appointment to have them installed and the Dealership has told me they will not fit. I also have 2.5 " level (spacer kit) on the front with a 1.75 Spacer on the rear. I will be switching to Bilsteins 5100 shortly but that is what I have for now. Anyone have an idea if the dealership is full of hot air or am a Fudged without a wheel spacer.
Old 05-02-2013, 06:41 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
I'm assuming you meant 35x12.5 Toyo AT2, not 25x12.5...
You'll fit. Lots of guys run the 35x12.5 tires on the stock rims with a 1/4" spacer which technically makes them a +12 offset. So at +10 you'll be okay.
Old 05-02-2013, 06:56 PM
Rep:17
Yes I did mean 35X12.5 I have made the correction. Thanks on the Quick reply
