Old 05-02-2013, 11:25 PM
Connie09 Connie09 is offline
Vehicle: 2010 Ram 1500
Color: Blue
Connie09 is on a distinguished road
Default 2010 Ram 1500 Towing
I am new to this Forum stuff But i had just bought a new camper last month i been trying to find some mods to the truck what would be the better mods the trailer i think is just to heavy for the rear end of my truck i have been thing of trying to find a 4 corner air bags system or if i should just find beefier coil springs and sway bars and bigger stoppers from letting the back of the truck sit so low .. ???
Old 05-03-2013, 12:07 AM
Butter's Avatar
Butter Butter is offline
Vehicle: 2010 Ram 1500 4x4 RC/SB
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
Take a look at Total Load Control in the vendor section, many have installed this set up with great success!
http://www.ramforumz.com/forumdisplay.php?f=231
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 05-03-2013, 10:26 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Total load control gets good reviews.
I have a set of Airlift 1000's in mine and they work great for towing. Even though you have a truck if the trailer is big enough you may need a weight distribution hitch.
By the way, welcome to the forum.
Old 05-05-2013, 12:46 PM
BoosTT BoosTT is offline
Vehicle: 2011 Ram 1500 Quad Sport 4x4
Color: Gray
Rep:15
BoosTT is on a distinguished road
You need a weight distributing hitch first!!!
Old 05-05-2013, 03:09 PM
Rep:220
That depends on the size of the trailer.
Unfortunately the drawback to the coil springs in the 1500 is the back will squat with weight on the hitch long before a weight distribution hitch is necessary. The same trailer I pulled behind and Astro van with no problem squatted the Ram enough I installed Airlifts. The Astro had the stock leaf springs.
Old 05-06-2013, 10:44 PM
Color: Blue
i ordered the Total load control last friday going to wait for it to get in the mail and install that we will see how that does but yah i noticed that the springs in the ram 09 to 13 are not the good for the loads .. so we will wait and see how good the air bags are
Old 05-08-2013, 02:42 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
For around the same price as the Total Load system you could have got a Husky Centerline weight distribution hitch with built in sway control (this is what I use towing a 6500 lbs Travel trailer). http://www.huskytow.com/product/husk...towing-system/
This would proof to be much safer than just air bags, but I guess it does depend on how heavy your trailer is.
Im my opinion anything over like 6000 lbs should have weight distribution hitch.
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 05-08-2013, 04:34 PM
Inferno10's Avatar
Inferno10 Inferno10 is offline
Vehicle: 2010 Ram 1500 Sport
Color: Inferno Red
Rep:12
Inferno10 is on a distinguished road
I would definitely go with a weight distribution hitch (with the sway control), and if you still get a bit of sag, add the airbags. The WDH/antisway setup doesnt just help with rear end sag, it makes for a much better, and safer towing setup. The camper I currently have is @ 4000lbs and I still use a WDH and an antisway bar.
Old 05-08-2013, 06:38 PM
jayace's Avatar
jayace jayace is offline
Vehicle: 2010 Ram 1500 Laramie 4x4 Crew
Color: Blue on Gray
jayace is on a distinguished road
I agree with this. I have a 4600lb dry trailer and even with my trailer unloaded and my WDH on I still get the sag. It's even worse once we're loaded for the weekend. I will probably get the Airlift 1000 to lift the back end up a bit.
Old 05-08-2013, 10:14 PM
Color: Blue
yah i have the weight distribution hitch my trailer dry is 6500lbs i still got a really good sage going on the truck thats why i was looking for airbags and stuff i had ordered them in and i will take pics of the truck with out the airbags full and then one with the airbags ... the only real reason is to keep that truck more level then anything and like i said that is my trailer dry now i add all my gear .. so once i got everything installed i will post pics
