Old 05-03-2013, 01:46 PM
PentaRam PentaRam is offline
Vehicle: 2013 Ram 1500 SLT
PentaRam is on a distinguished road
Default LSD or standard differential?
With all the issues out there with trucks arriving with the wrong gears, how can those of us that paid extra for the LSD be sure we actually have it?
I know you can look at the tag on the diff to see what gears are inside but will that same tag confirm if its a LSD vs standard diff?
Old 05-03-2013, 02:36 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Check your build sheet for (DASP Anti-Spin differential rear axle) this is the LSD.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 05-03-2013, 02:58 PM
LS1EB's Avatar
LS1EB LS1EB is offline
Vehicle: 2013 Ram 1500 QC 4X4
Color: Copperhead Pearl
Rep:54
LS1EB will become famous soon enough
Funner way is to do a burnout and check for 2 parallel lines of rubber on the road, open diff will typically only spin one tire or alternate between the two.
2013 QC Express 4x4 Hemi, Copperhead Pearl, painted tails & 3rd, black badges & wheels, 20% tint.
Old 05-03-2013, 03:51 PM
LOL, I actually thought about doing this but it will have to be in some dirt 'cause I seriously doubt that my V6 has the torque to break 'em loose on the pavement!
Old 05-03-2013, 11:10 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
My hemi has trouble breaking them loose with the 3.55's and the LSD.
Old 05-04-2013, 09:13 AM
shaner82's Avatar
shaner82 shaner82 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:47
shaner82 is on a distinguished road
I don't have the LSD and still have trouble breaking them loose on dry pavement. It's not due to a lack of power, it's due to having an auto transmission. Give me a manual transmission and I'll leave half my tires buried in the pavement.
Old 05-04-2013, 10:04 AM
turbohawk's Avatar
turbohawk turbohawk is offline
Vehicle: 2013 1500 4x4 5.7 6spd
Trim Level: Express QC 6'4" bed
Color: Polar White
Rep:44
turbohawk is on a distinguished road
Make sure traction control switch is OFF too...
Old 05-05-2013, 09:55 PM
Dmcphee13ram Dmcphee13ram is offline
Vehicle: 2013 outdoorsman
Color: Copperhead pearl
Dmcphee13ram is on a distinguished road
Does the LSD have a code on the axle tag at all?
Old 05-05-2013, 10:04 PM
glaizinman glaizinman is offline
Vehicle: 2007 dodge ram 1500 4x4
Trim Level: laramie
Color: black peral
glaizinman is on a distinguished road
I have a 07 ram 1500 with a hemi with 3:92 anti spin rear and i can not break the tires loose even with the traction control off. Is this normal?
Old 05-05-2013, 10:55 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
I test drove a 13 Hemi with 3.55's and no LSD and a light power brake launch got one tire spinning a bit on dry pavement.
But I noticed quickly the issue is, first gear is too tall in these trucks.
The truck is a bit soft on launch.
You shouldn't need the 3.92's to break the tires loose on a pick up truck (that doesn't have a ton of weight over the rear tires) with a large V8 under the hood.
As for the 07. The Hemi had 340 hp back then, and less torque than currently too.
I would not expect you to be able to break the tires loose on an 07 when it's tough to do it on a 13.
Hopefully the 8 speed auto rectifies this by having better gearing for low speed acceleration.
2015 Dodge Challenger Hellcat - 8spd
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's -GONE-
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
